LXS volume problem[solved]
nigec
Post by nigec »
Me again :)
Luxcore appears to totally ignore volume in a LXS file, no volume effect shows and nothing volume related exports if I try and save the scene from luxcoreui
I've tried both the SU2LX exporter and the old Blender one to make sure its not exporter related
The render should look like:
In Luxcoreui its just the lit cube
I wasn't really bothered about volume but I was hoping to show case how fast Luxcore was doing lasers compared to Thea.. I'm trying to get the Thea/SU users interested, and it needs to be Sketchup doing it not Blender
volume_error.zip
(2.7 KiB) Downloaded 296 times
Re: LXS volume problem
Yes, volumes are just ignored by LXS parser. I will check if the support can be added with a reasonable amount of work.
nigec
Post by nigec »
Thanks for taking a look :)
It would be cool if you can
I have added the support for volumes to the LXS parser. Note:
1) the scattering value should be something like "0.006" instead of "0.6", it is too strong;
2) the volume is exported as "heterogeneous" even if the scattering value is constant (aka "homogeneous" volume). If you export the volume as homogeneous, the rendering will be an order of magnitude faster.
nigec
Post by nigec »
Awesome, thank you :)
nigec
Post by nigec »
it works great, thanks again
