Out of interested I wanted to have a go building a simple application with QT but I noticed there is no lib files in the SDK
Sadly I don't have enough ram to build from source, last time my system crashed and it wasn't happy when I rebooted lol
Are the libs available?
sdk lib files
Re: sdk lib files
Nobody?
I just tried again to build from source and my system just crashed and burned and I had a hellish time getting it to reboot
It gets to the linking phase and I'm running at 90% + memory usage for a very long time
- alpistinho
- Developer
Re: sdk lib files
If memory usage is the issue, you should use less threads for compiling. I don't know how to set that on Windows, but it shouldn't be too hard
Re: sdk lib files
Maybe i can build, but i have no clue how. Assuming all the needed files can be compressed small enough for sending back to you.
Re: sdk lib files
This is my first time using cmake so I'm not sure how to limit the threads, looking online its something like "-j number threads"
@Fox I was assuming I need to do:
I would of thought the SDK would have the lib file already there
I'll have a go at limiting the threads and have another go
cd C:\Path\to\luxcorerender\WindowsCompile\
.\cmake-build-x64.bat /dll
create-sdk.batI'll have a go at limiting the threads and have another go
Re: sdk lib files
Let me know if i posted right files. \luxcorerender\WindowsCompile\luxcorerender
https://drive.google.com/file/d/1C8PrS_ ... sp=sharing
Re: sdk lib files
No, I have those, but I managed to build luxcore lib's by reducing the threads to 3
Thanks for trying Fox
Re: sdk lib files
I have to say I also wonder why those files are not included in the SDK release packages.
