LuxcoreUI closed unexpectedly while rendering "food" scene
Posted: Sun Apr 07, 2019 3:45 am
by motaman
luxcoreUI was rendering the scene pretty well, then it closed out of nowhere.
here is my .cfg file , idk if i did something wrong
opencl.cpu.use = 0
opencl.gpu.use = 1
# opencl.devices.select = "1"
opencl.native.threads.count = 1
path.pathdepth.total = 11
path.pathdepth.diffuse = 5
path.pathdepth.glossy = 5
path.pathdepth.specular = 10
sampler.sobol.adaptive.strength = 0.80000001192092896
sampler.random.adaptive.strength = 0.80000001192092896
sampler.metropolis.largesteprate = 0.40000000000000002
sampler.metropolis.maxconsecutivereject = 256
sampler.metropolis.imagemutationrate = 0.10000000000000001
film.height = 1080
renderengine.type = "PATHOCL"
sampler.type = "SOBOL"
scene.epsilon.max = 0.10000000149011612
film.width = 1080
film.opencl.enable = 1
film.filter.width = 1.5
film.filter.type = "BLACKMANHARRIS"
scene.epsilon.min = 9.9999997473787516e-06
lightstrategy.type = "POWER"
path.forceblackbackground.enable = 0
renderengine.seed = 1
batch.haltspp = 1500
batch.haltthreshold.filter.enable = 1
batch.halttime = 0
batch.haltthreshold.warmup = 32
batch.haltthreshold.stoprendering.enable = 1
batch.haltthreshold = 0.01171875
batch.haltthreshold.step = 256
film.imagepipelines.1.0.type = "BCD_DENOISER"
film.imagepipelines.1.0.scales = 3
film.imagepipelines.1.0.histdistthresh = 1
film.imagepipelines.1.0.patchradius = 1
film.imagepipelines.1.0.searchwindowradius = 4
film.imagepipelines.1.0.filterspikes = 0
film.imagepipelines.1.1.type = "NOP"
film.imagepipelines.1.2.type = "TONEMAP_LINEAR"
film.imagepipelines.1.2.scale = 0.80000001192092896
film.imagepipelines.1.3.type = "GAMMA_CORRECTION"
film.imagepipelines.1.3.value = 2.2000000000000002
film.imagepipelines.0.0.type = "NOP"
film.imagepipelines.0.1.type = "TONEMAP_LINEAR"
film.imagepipelines.0.1.scale = 0.80000001192092896
film.imagepipelines.0.2.type = "GAMMA_CORRECTION"
film.imagepipelines.0.2.value = 2.2000000000000002
film.imagepipelines.1.radiancescales.0.enabled = 1
film.imagepipelines.1.radiancescales.0.globalscale = 1
film.imagepipelines.1.radiancescales.0.rgbscale = 1 1 1
film.imagepipelines.0.radiancescales.0.enabled = 1
film.imagepipelines.0.radiancescales.0.globalscale = 1
film.imagepipelines.0.radiancescales.0.rgbscale = 1 1 1
film.outputs.0.index = 0
film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
film.outputs.1.type = "RGB_IMAGEPIPELINE"
film.outputs.1.index = 1
film.outputs.1.filename = "RGB_IMAGEPIPELINE_1.png"
scene.file = "scene.scn"
Re: LuxcoreUI closed unexpectedly while rendering "food" scene
Posted: Sun Apr 07, 2019 7:35 am
by nigec
Do a bat file and start luxcoreui with it something like:
"C:\luxcorerender/luxcoreui.exe" -d "C:\Users\nige\Desktop\Batchzipper\scenes\bigmonkey" "bigmonkey.cfg" -D "batch.halttime" "10"
pause
"batch.halttime stops the render after 10 seconds
the pause keeps the cmd window open so you can see what went wrong hopefully
Posted: Sun Apr 07, 2019 10:35 am
Or just run the command from a shell (i.e. cmd.exe) so the output is not lost.
Posted: Sun Apr 07, 2019 3:52 pm
by motaman
i did both the batch file and running from the cmd directly.
in those cases they stoped here, so i couldn't get the error
Posted: Sun Apr 07, 2019 4:03 pm
by motaman
I did however another render opening the .cfg file from the UI .
I got this error and then the program closed.
Posted: Sun Apr 07, 2019 4:26 pm
motaman wrote: Sun Apr 07, 2019 3:52 pm
It is likely to be a problem with your GPU: Intel GPUs are extremely limited and, most of the times, they are unable to run complex GPU computing tasks (like rendering). You should use PATHCPU instead of PATHOCL render engine so only the CPU is used.
Posted: Sun Apr 07, 2019 4:58 pm
motaman wrote: Sun Apr 07, 2019 4:03 pm
This looks like the bug I reported here:
https://github.com/LuxCoreRender/LuxCore/issues/183
Can you post your scene?
By the way, you could compile in release mode instead of debug mode to prevent assertions from being raised.
Posted: Sun Apr 07, 2019 6:13 pm
by motaman
here is my .scn file
Posted: Sun Apr 07, 2019 7:01 pm
by motaman
B.Y.O.B. wrote: Sun Apr 07, 2019 4:58 pm
yep i compiled in release mode and worked, thanks a lot B.Y.O.Baby
and dade
