LuxcoreUI closed unexpectedly while rendering "food" scene
motaman
Post by motaman »
:? luxcoreUI was rendering the scene pretty well, then it closed out of nowhere.
here is my .cfg file , idk if i did something wrong :oops:
opencl.cpu.use = 0
opencl.gpu.use = 1
# opencl.devices.select = "1"
opencl.native.threads.count = 1
path.pathdepth.total = 11
path.pathdepth.diffuse = 5
path.pathdepth.glossy = 5
path.pathdepth.specular = 10
sampler.sobol.adaptive.strength = 0.80000001192092896
sampler.random.adaptive.strength = 0.80000001192092896
sampler.metropolis.largesteprate = 0.40000000000000002
sampler.metropolis.maxconsecutivereject = 256
sampler.metropolis.imagemutationrate = 0.10000000000000001
film.height = 1080
renderengine.type = "PATHOCL"
sampler.type = "SOBOL"
scene.epsilon.max = 0.10000000149011612
film.width = 1080
film.opencl.enable = 1
film.filter.width = 1.5
film.filter.type = "BLACKMANHARRIS"
scene.epsilon.min = 9.9999997473787516e-06
lightstrategy.type = "POWER"
path.forceblackbackground.enable = 0
renderengine.seed = 1
batch.haltspp = 1500
batch.haltthreshold.filter.enable = 1
batch.halttime = 0
batch.haltthreshold.warmup = 32
batch.haltthreshold.stoprendering.enable = 1
batch.haltthreshold = 0.01171875
batch.haltthreshold.step = 256
film.imagepipelines.1.0.type = "BCD_DENOISER"
film.imagepipelines.1.0.scales = 3
film.imagepipelines.1.0.histdistthresh = 1
film.imagepipelines.1.0.patchradius = 1
film.imagepipelines.1.0.searchwindowradius = 4
film.imagepipelines.1.0.filterspikes = 0
film.imagepipelines.1.1.type = "NOP"
film.imagepipelines.1.2.type = "TONEMAP_LINEAR"
film.imagepipelines.1.2.scale = 0.80000001192092896
film.imagepipelines.1.3.type = "GAMMA_CORRECTION"
film.imagepipelines.1.3.value = 2.2000000000000002
film.imagepipelines.0.0.type = "NOP"
film.imagepipelines.0.1.type = "TONEMAP_LINEAR"
film.imagepipelines.0.1.scale = 0.80000001192092896
film.imagepipelines.0.2.type = "GAMMA_CORRECTION"
film.imagepipelines.0.2.value = 2.2000000000000002
film.imagepipelines.1.radiancescales.0.enabled = 1
film.imagepipelines.1.radiancescales.0.globalscale = 1
film.imagepipelines.1.radiancescales.0.rgbscale = 1 1 1
film.imagepipelines.0.radiancescales.0.enabled = 1
film.imagepipelines.0.radiancescales.0.globalscale = 1
film.imagepipelines.0.radiancescales.0.rgbscale = 1 1 1
film.outputs.0.index = 0
film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
film.outputs.1.type = "RGB_IMAGEPIPELINE"
film.outputs.1.index = 1
film.outputs.1.filename = "RGB_IMAGEPIPELINE_1.png"
scene.file = "scene.scn"
instagram: motaman.art
nigec
Re: LuxcoreUI closed unexpectedly while rendering "food" scene
Post by nigec »
Do a bat file and start luxcoreui with it something like:
"C:\luxcorerender/luxcoreui.exe" -d "C:\Users\nige\Desktop\Batchzipper\scenes\bigmonkey" "bigmonkey.cfg" -D "batch.halttime" "10"
pause
"batch.halttime stops the render after 10 seconds
the pause keeps the cmd window open so you can see what went wrong hopefully
Or just run the command from a shell (i.e. cmd.exe) so the output is not lost.
motaman
Post by motaman »
i did both the batch file and running from the cmd directly. :?
in those cases they stoped here, so i couldn't get the error
motaman
Post by motaman »
I did however another render opening the .cfg file from the UI .
I got this error and then the program closed.
motaman wrote: Sun Apr 07, 2019 3:52 pm i did both the batch file and running from the cmd directly. :?
It is likely to be a problem with your GPU: Intel GPUs are extremely limited and, most of the times, they are unable to run complex GPU computing tasks (like rendering). You should use PATHCPU instead of PATHOCL render engine so only the CPU is used.
motaman wrote: Sun Apr 07, 2019 4:03 pm I did however another render opening the .cfg file from the UI .
This looks like the bug I reported here: https://github.com/LuxCoreRender/LuxCore/issues/183
Can you post your scene?
By the way, you could compile in release mode instead of debug mode to prevent assertions from being raised.
motaman
Post by motaman »
here is my .scn file
scene.scn
(192.93 KiB) Downloaded 1094 times
motaman
Post by motaman »
B.Y.O.B. wrote: Sun Apr 07, 2019 4:58 pm
yep i compiled in release mode and worked, thanks a lot B.Y.O.Baby 8-) and dade
