I'm trying to build LuxCore API SDK release v2.1 in windows with openCL support.
First cmake couldn't find openCL , i solved that with intel SDK for openCL , then i tried to configure again and now cmake can't find the required Boost files
CMAKE VERSION DETECTED 3.13.4
The C compiler identification is GNU 6.3.0
The CXX compiler identification is GNU 6.3.0
Check for working C compiler: C:/MinGW/bin/gcc.exe
Check for working C compiler: C:/MinGW/bin/gcc.exe -- works
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Detecting C compile features
Detecting C compile features - done
Check for working CXX compiler: C:/MinGW/bin/g++.exe
Check for working CXX compiler: C:/MinGW/bin/g++.exe -- works
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Detecting CXX compile features
Detecting CXX compile features - done
Building mode: Release
Found OPENCL: C:/Windows/System32/OpenCL.dll
Found OpenGL: opengl32
Looking for pthread.h
Looking for pthread.h - not found
Found Threads: TRUE
Could NOT find Boost
CMake Error at CMakeLists.txt:137 (MESSAGE):
--> Could not locate required Boost files - Please check
Configuring incomplete, errors occurred!
See also "C:/Users/Daniel/Desktop/LUXAPIbuild/CMakeFiles/CMakeOutput.log".
See also "C:/Users/Daniel/Desktop/LUXAPIbuild/CMakeFiles/CMakeError.log".
To correctly generate pyluxcoretools files you also need to have Python 3.5 with package PySide2 installed (see same procedure, a few rows below: In order to create an official release...).
I will update the README in order to make this more clear.
However, if you don't need pyluxcoretools, even with that error you have all the required luxcore binaries.
Sorry, am new with all of this, i did follow the procedure described on the above Windows Compile page, but i too got No OpenCL support... How did you get it building with OCL?
kintuX wrote: Wed Apr 10, 2019 11:41 am
Sorry that this is not clearly explained in the procedure, I'll fix that.
Thanks. It did the thing. OCL found, but now am out of space already ordered extra. Should be here in about a week and will do some cleaning over the weekend.
