cfg and scn paths
Posted: Tue Mar 26, 2019 9:18 am
by nigec
My Python project has a scene folder, all the examples have the path "scene.file = scenes/cornell/cornell.scn" so it will work fine
But if I export from Blender or whatever I just get the scn name, so unless I manually add the path to the files or move my project into the folder I'm stuck
How do I open a cfg file with the full path so it will load the scn file content in Python
I've done a search and not found anything
Re: cfg and scn paths
Posted: Tue Mar 26, 2019 10:21 am
You can use the "File name resolver" to add paths to the list of places where LuxCore will look. You can add a new path by calling LuxCore API function AddFileNameResolverPath(path):
https://github.com/LuxCoreRender/LuxCor ... ore.h#L149
Posted: Tue Mar 26, 2019 1:02 pm
by nigec
I don't appear to be able to get it to work
I suck at C++ (and python really) but I found this in luxcoreui.cpp:
if (configFileName.compare("") != 0) {
// Clear the file name resolver list
luxcore::ClearFileNameResolverPaths();
// Add the current directory to the list of place where to look for files
luxcore::AddFileNameResolverPath(".");
// Add the .cfg directory to the list of place where to look for files
boost::filesystem::path path(configFileName);
luxcore::AddFileNameResolverPath(path.parent_path().generic_string());
so
Is there a conversion happening to get path.parent_path().generic_string()?
Is this the folder path?
Posted: Tue Mar 26, 2019 1:19 pm
Are you working in Python or C++ ?
nigec wrote: Tue Mar 26, 2019 1:02 pm
Yes, it gets the parent directory of where the current render.cfg file is (.parent_path()) and than convert the Boost "path" object to a generic string (.generic_string()).
Yes, you have to pass to luxcore::AddFileNameResolverPath() a string with the directory to add to the list of places where to look. Be careful with if the string identify and absolute or relative path.
LuxCoreUI adds to the list the current path (i.e. ".") and the directory where the render.cfg file is. I assume you need to do the same.
Posted: Tue Mar 26, 2019 1:47 pm
by nigec
I'm working with Python, I was just looking for something in context, all the Python examples preload the scene.. even the pyside example
I still haven't got it working.. its not a good day... lol
I'll try a simple script rather than trying to add it to my current project
Posted: Tue Mar 26, 2019 2:22 pm
Check the log output, you should have something like:
[LuxCore][0.003] File Name Resolver Configuration:
[LuxCore][0.003] .
[LuxCore][0.003] scenes/cornell
The list should include the directory where scene.scn file is.
Posted: Tue Mar 26, 2019 2:52 pm
by nigec
Yes that works, so its something to do with how I'm loading the cfg file
Posted: Tue Mar 26, 2019 5:05 pm
by nigec
Still no joy:
print("RenderConfig and RenderSession examples (requires scenes directory)...")
pyluxcore.AddFileNameResolverPath(".")
pyluxcore.AddFileNameResolverPath("scenes/cornell")
cfgFileName ="cornell.cfg"
props = pyluxcore.Properties(cfgFileName)
# Change the render engine to PATHCPU
props.Set(pyluxcore.Property("renderengine.type", ["PATHCPU"]))
config = pyluxcore.RenderConfig(props)cornell.cfg
session = pyluxcore.RenderSession(config)
session.Start()
the following works with a the path scenes/cornell/cornell.cfg
Posted: Tue Mar 26, 2019 7:02 pm
by nigec
Here's an example I did with
guizero I don't really understand why its not working, I've tried everything I can think of with the path.. could it be a python issue?
from guizero import *
import random
import time
import sys
import os
from array import *
sys.path.append("./lib")
import pyluxcore
count = 0
def loadscene():
print("LuxCore %s" % pyluxcore.Version())
pyluxcore.Init()
session.Start()
counter_loop()
def counter_loop():
global count
startTime = count
#Update statistics
if count < 5:
button.disable()
session.UpdateStats()
stats = session.GetStats()
print("[Elapsed time: %3d/5sec][Samples %4d][Avg. samples/sec % 3.2fM on %.1fK tris]" % (
stats.Get("stats.renderengine.time").GetFloat(),
stats.Get("stats.renderengine.pass").GetInt(),
(stats.Get("stats.renderengine.total.samplesec").GetFloat() / 1000000.0),
(stats.Get("stats.dataset.trianglecount").GetFloat() / 1000.0)))
count += 1
counter.value = count
app.after(1000, counter_loop)
else:
button.enable()
count = 0
session.Stop()
session.GetFilm().Save()
picture = Picture(app, image="RGB_IMAGEPIPELINE_0.png")
app = App(title="counter")
pyluxcore.ClearFileNameResolverPaths()
props = pyluxcore.Properties("cornell.cfg")
#props = pyluxcore.Properties("scenes/cornell/cornell.cfg")
props.Set(pyluxcore.Property("film.outputs.0.type", ["RGB_IMAGEPIPELINE"]))
props.Set(pyluxcore.Property("film.outputs.0.filename", ["RGB_IMAGEPIPELINE_0.png"]))
title_box = Box(app, width="fill", align="top", border=True)
title = Text(title_box, text="Header")
title_box.text_color="white"
title_box.bg="grey"
button = PushButton(app, command=loadscene, text="start loop")
counter = Text(app, "stopped")
app.display()
Posted: Tue Mar 26, 2019 7:12 pm
Have you tried using an absolute path instead of "scenes/cornell"?
Is "scenes/cornell" even a valid path?
If it is a valid relative path, maybe you are starting the script from the wrong location?
