cfg and scn paths
cfg and scn paths
My Python project has a scene folder, all the examples have the path "scene.file = scenes/cornell/cornell.scn" so it will work fine
But if I export from Blender or whatever I just get the scn name, so unless I manually add the path to the files or move my project into the folder I'm stuck
How do I open a cfg file with the full path so it will load the scn file content in Python
I've done a search and not found anything
Re: cfg and scn paths
You can use the "File name resolver" to add paths to the list of places where LuxCore will look. You can add a new path by calling LuxCore API function AddFileNameResolverPath(path):
https://github.com/LuxCoreRender/LuxCor ... ore.h#L149
I don't appear to be able to get it to work
I suck at C++ (and python really) but I found this in luxcoreui.cpp:
so
Is there a conversion happening to get path.parent_path().generic_string()?
Is this the folder path?
if (configFileName.compare("") != 0) {
// Clear the file name resolver list
luxcore::ClearFileNameResolverPaths();
// Add the current directory to the list of place where to look for files
luxcore::AddFileNameResolverPath(".");
// Add the .cfg directory to the list of place where to look for files
boost::filesystem::path path(configFileName);
luxcore::AddFileNameResolverPath(path.parent_path().generic_string());
}Code: Select all
luxcore::AddFileNameResolverPath(path.parent_path().generic_string());Is this the folder path?
Are you working in Python or C++ ?
LuxCoreUI adds to the list the current path (i.e. ".") and the directory where the render.cfg file is. I assume you need to do the same.
Yes, it gets the parent directory of where the current render.cfg file is (.parent_path()) and than convert the Boost "path" object to a generic string (.generic_string()).nigec wrote: Tue Mar 26, 2019 1:02 pm Is there a conversion happening to get path.parent_path().generic_string()?
Yes, you have to pass to luxcore::AddFileNameResolverPath() a string with the directory to add to the list of places where to look. Be careful with if the string identify and absolute or relative path.
I'm working with Python, I was just looking for something in context, all the Python examples preload the scene.. even the pyside example
I still haven't got it working.. its not a good day... lol
I'll try a simple script rather than trying to add it to my current project
Check the log output, you should have something like:
The list should include the directory where scene.scn file is.
[LuxCore][0.003] File Name Resolver Configuration:
[LuxCore][0.003] .
[LuxCore][0.003] scenes/cornell
Yes that works, so its something to do with how I'm loading the cfg file
Still no joy:
the following works with a the path scenes/cornell/cornell.cfg
print("RenderConfig and RenderSession examples (requires scenes directory)...")
pyluxcore.AddFileNameResolverPath(".")
pyluxcore.AddFileNameResolverPath("scenes/cornell")
cfgFileName ="cornell.cfg"
props = pyluxcore.Properties(cfgFileName)
# Change the render engine to PATHCPU
props.Set(pyluxcore.Property("renderengine.type", ["PATHCPU"]))
config = pyluxcore.RenderConfig(props)cornell.cfg
session = pyluxcore.RenderSession(config)
session.Start()Re: cfg and scn paths
Here's an example I did with guizero I don't really understand why its not working, I've tried everything I can think of with the path.. could it be a python issue?
from guizero import *
import random
import time
import sys
import os
from array import *
sys.path.append("./lib")
import pyluxcore
count = 0
def loadscene():
print("LuxCore %s" % pyluxcore.Version())
pyluxcore.Init()
session.Start()
counter_loop()
def counter_loop():
global count
startTime = count
#Update statistics
if count < 5:
button.disable()
session.UpdateStats()
stats = session.GetStats()
print("[Elapsed time: %3d/5sec][Samples %4d][Avg. samples/sec % 3.2fM on %.1fK tris]" % (
stats.Get("stats.renderengine.time").GetFloat(),
stats.Get("stats.renderengine.pass").GetInt(),
(stats.Get("stats.renderengine.total.samplesec").GetFloat() / 1000000.0),
(stats.Get("stats.dataset.trianglecount").GetFloat() / 1000.0)))
count += 1
counter.value = count
app.after(1000, counter_loop)
else:
button.enable()
count = 0
session.Stop()
session.GetFilm().Save()
picture = Picture(app, image="RGB_IMAGEPIPELINE_0.png")
app = App(title="counter")
pyluxcore.ClearFileNameResolverPaths()
props = pyluxcore.Properties("cornell.cfg")
#props = pyluxcore.Properties("scenes/cornell/cornell.cfg")
props.Set(pyluxcore.Property("film.outputs.0.type", ["RGB_IMAGEPIPELINE"]))
props.Set(pyluxcore.Property("film.outputs.0.filename", ["RGB_IMAGEPIPELINE_0.png"]))
title_box = Box(app, width="fill", align="top", border=True)
title = Text(title_box, text="Header")
title_box.text_color="white"
title_box.bg="grey"
button = PushButton(app, command=loadscene, text="start loop")
counter = Text(app, "stopped")
app.display()Re: cfg and scn paths
Have you tried using an absolute path instead of "scenes/cornell"?
Is "scenes/cornell" even a valid path?
If it is a valid relative path, maybe you are starting the script from the wrong location?
