Page 5 of 6
				Re: Baking Bevel in Cycles
				Posted: Fri Mar 12, 2021 8:49 am
				by Dez!
				This render of the cube is the coolest render over the past few years.
				Posted: Fri Mar 12, 2021 1:18 pm
				Posted: Fri Mar 12, 2021 1:24 pm
				by AndreasResch
				The agony of having to wait. Ahhhhhhhhh!
				Posted: Fri Mar 12, 2021 1:31 pm
				by TAO
				amazing results as always.
				Posted: Fri Mar 12, 2021 1:36 pm
				by marcatore
				and now..concave shape ...
				Posted: Fri Mar 12, 2021 3:24 pm
				by tokiop
				Great results Dade ! This will be very useful for realistic renders...
Do you already have an idea on how bevel radius will be controllable ? Edge weight, texture map, material based... maybe this is more an plugin implementation topic though.
The thread seems to have multiple topics : 1) bevel baking (fixed?) 2) microfacet based normal mapping (interesting ongoing topic) 3) capsule bevel development (interesting ongoing topic), maybe splitting the thread would make sense ?
Have a great day and week end !
				Posted: Thu Mar 18, 2021 7:47 am
				by AndreasResch
				A last follow up on the normal mapping issue. Here are two comparisons. The left one uses displacement to create the surface structure, the right one uses normal mapping to do so. As you can see, in the displacement version the gray floor is properly reflected in the elevated areas. In the normal version, the reflection is very dark.
I'll leave it up to you guys now to decide if this is worth investigating.
				Posted: Thu Mar 18, 2021 9:41 am
				Know limits as already explained in this thread. Nothing new to investigate.
Maybe you just need to study more...
				Posted: Thu Mar 18, 2021 9:50 am
				by AndreasResch
				I'd appreciate it if you stay away from ad hominems. Adding a winky eye doesn't make them funnier. Cheers.
				Posted: Thu Mar 18, 2021 12:20 pm
				by tokiop
				AndreasResh, I find you test well done and test / illustrate well current limitations. Comparing with displacement is a good idea. So thanks for taking time for this and sharing your results.
I wonder if displacement in Lux would exhibit the samed bright border (fresnel?) seen in the Cycles renders, but it might also be due to the shaders.
