Page 3 of 3
Re: Direct Light Sampling Cache errors
Posted: Sun Nov 11, 2018 11:18 am
here, isolated issue (it seems like sky reflection is the problem)
hdri works normally, sky and sun works only if sky is not visible for glossy rays
If I add sun to hdri the issue appears again :lol:
Posted: Sun Nov 11, 2018 11:37 am
lacilaci wrote: Sun Nov 11, 2018 11:18 am If I add sun to hdri the issue appears again :lol:
Yes, like I said, it is a MIS problem: if you set max path depth to 1 (in .cfg file), it works fine, if set to 2 (MIS enabled), it doesn't. It happens because some cache entry, near a shadow boundary, has 2 entries (sun+sky) others has sky only (sun always not visible there). This change the weights of MIS and triggers the problem.
It should be possible to recreate the problem also with just 2 area lights (i.e. it is not related the light source types but to Glossy code for Sample() and Evaluate()).
Posted: Mon Nov 12, 2018 11:15 am
Dade wrote: Sun Nov 11, 2018 11:37 am
When corona was introducing for the first time their new light solver that also handles many lights scenarios well. They too had similar issue I think: https://corona-renderer.com/forum/index ... #msg132828
