Direct Light Sampling Cache errors
Asticles
Post by Asticles »
Hi all,
I'm having some strange artifacts with Direct Light Sampling Cache:
I've created this blend file with the error:
caching.blend
(662.84 KiB) Downloaded 1001 times
Edit: Have cleaned the file.
Best regards.
stefdln
Re: Direct Light Sampling Cache errors
Post by stefdln »
I guess this has been exposed inthis thread
viewtopic.php?f=4&t=705
and corrected in the latest daily build (not sure about this one)
Cheers
Asticles
Post by Asticles »
Thanks for your response, I've tested it with this build and the same happens.
https://github.com/LuxCoreRender/LuxCor ... tag/latest
Regards
It is a different problem I'm currently investigating.
The .blend file is missing the textures.
Dade wrote: Tue Nov 06, 2018 10:06 am It is a different problem I'm currently investigating.
Is this the, hdri/skylight cache sampling issue? Can this be solved without fiddling with warmup samples?
Asticles
Post by Asticles »
Sorry, I cannot redistribute the textures.
https://www.textures.com/download/pbr0075/133109
If you want to download them, but I've cleaned the file posted above. It also makes the same artifacts but without the textures.
Regards
Asticles
Post by Asticles »
Hope this helps ;)
1. It only happens with the Sky.
2. It gets more prominent with 'Use Ground Color'.
3. Goes away when Ground Color is set to Black, while changing Ground Albedo Color results are fine (w/o splotches).
Edit: Missing description for Albedo versions: above is Black, below is White (if in doubt, observe sky coloration). ;)
kintuX wrote: Tue Nov 06, 2018 8:29 pm 2. It gets more prominent with 'Use Ground Color'.
Very strange, I will check: it sounds like some kind of normal-related problem (aka taking light from "down" instead of "up").
