Two well known luxcore problems.
Re: Two well known luxcore problems.
Martini wrote: Tue Aug 24, 2021 2:24 pm And I guess that means we would have to do something similar (at least for the Disney material).
Yes, by default, we must strictly follow Disney material standard but we can extend it like Cycles did.
juangea
Post by juangea »
First things first, If in Cycles Multiscatter GGX leads to Blackness with 1.0 IOR then it should be reported as a BUG AFAIK, so if you can please do it :)
Second, I think elevating the current Disney material implementation to the 2015 version could be a first great step, this would ease the interpretation of Cycles materials a lot and will allow us to use "agnostic" assets that comes from libraries that are already prepared for Cycles, that would save a lot of work time.
Another thing that kills the possibility of using Cycles materials is the mapping node, while both renders have similar nodes, I don't get why the Cycles mapping node is not interpreted and translated when used with Luxcore, I think this has been mentioned in the past, but may be some kind of limitation?
Anyways, everything is important, you probably have an order of development of some kind, I just wanted to remember these two things too :)
Uh... regarding the disney material... the white halo at the tangent on bright materials is my luxcore problem number 3
chuchur
Post by chuchur »
if I understand Disney implementation right, subsurface scattering is pure fake. I guess to make true subsurface scattering volumetrics should be used.
The material here as well as the Luxcore disney doesn't have SSS of any sort.
This bright rim is appearing at grazing angle in certain lighting condition.
Sharlybg wrote: Fri Aug 27, 2021 2:29 pm The material here as well as the Luxcore disney doesn't have SSS of any sort.
Try to wonder what I'm asking ... right, a test scene.
Have you tried to use the Disney parameters with Cycles ?
Sorry here it is :
Rim.zip
(1.78 MiB) Downloaded 1366 times
Is it a BiDir only problem ?
Path:
BiDir:
Yes, it is easy to spot the problem using light tracing only rendering:
(the fireflies on the edges)
Do you think you can do anything to reduce this halo on bidir?
That would be great!
