Page 3 of 8
Posted: Fri Jul 09, 2021 3:37 pm
by daros
Totally misleading test. If you compare closed technologies with open technologies, you have to be much stricter in setting up such tests. Closed technologies steal here and there in order to gain speed.... The tests must be able to highlight these tricks.
And the funny thing is that you don't even appreciate Luxcore's crazy good light distribution compared to most others. And you can easily edit Luxcore's render to make it look like Corona's, but you can't edit Corona's render to make it look like Luxcore's because Corona's image simply doesn't have the same quality of light distribution. It's the difference between a raw file of a photo taken with a professional camera and a contrasty image created by an i phone... it is obvious that for someone the iphone photo is more attractive. Not for the photography professional who knows how to post produce 100 different types of color corrections from a raw file. But he won't be able to do that starting from a poppy cell phone photo. No serious person compares an iphone photo to a raw from a Sony a7r III. To be kind I see some naivety in this test. Otherwise I think it was done in bad faith and with specific goals.
Posted: Fri Jul 09, 2021 5:16 pm
The issue is that not everyone have a degree in Computer science and Light transport research. Most artist just know at best the purposes of the settings the engine just expose. But such kind of information or argument can't easily proove by an artist. Only someone with the correct knowledge can explain How wrong this is.
At least 2 of the compared engine are opensource. if there is a way to show that this isn't a correct test we should at least explain that.
We can take a cornell box render scene like the one in page 2 render in both Blender and Luxcore output as full EXR same path settings and no clamping. and show why the result is unfair and biased.
Otherwise millions of people are going to believe this big Lie and see Lux as the forever snail.
If someone want I am ready to make scene for the experiment.
Vote for Luxcore! Vote for Quality!
Posted: Fri Jul 09, 2021 6:41 pm
by FarbigeWelt
daros wrote: Fri Jul 09, 2021 3:37 pm
Congratulation! I very appreciate your comparison of dull smart phone phtography with good camera's high dynamic raw shots. (Mine example was a bit more sarcastic: 4 colors cartoons on cheap grey-yellowish paper vs. 9 color fine art photohraphic prints on high glossy or velvet smooth >200 g/m^2 paper.
Vote for Luxcore!
Vote for Quality!
German common expression: "Gut' Ding' will Weile haben!".
Posted: Sat Jul 10, 2021 10:11 am
by zuljin3d
There are many details, E-Cycle vs Cycles is clear that loose a lot of quality, that's what E-Cycles is basically based on.
All the quality of the E-cycles rests on these settings:
Posted: Sat Jul 10, 2021 10:35 am
Do someone know where i can find the russian roulette settings ?
I lost it in the addon.In the past BYOBY just show me but it is no longer
available in the link :
viewtopic.php?f=4&t=1741&hilit=Russian+Roulette
Posted: Sat Jul 10, 2021 10:37 am
Sorry I remenber i have to add thoses lines yself
Posted: Sat Jul 10, 2021 11:00 am
This is a rendering with intentionally bad RR settings (
0.97M samples/sec):
This is a rendering with default RR settings (
3.41M samples/sec):
This is a rendering with intentionally fast RR settings (
6.12M samples/sec):
As you see I can manipolate the samples/sec however I want. But check the "rays per samples": the first one traces ~36 rays per samples while the last one only ~4 per samples. Clearly the last one is perceived 6 time "faster" ... but it isn't, it has just more noise and potentially fireflies.
The 3 renderings are still unbiased so they converge at the same solution on the long run.
In the case of Cycles and its clone, I assume by looking at the rendering, they are instead biasing more or less the rendering, cutting stuff. In particular, it is quite evident like E-Cycles does, most of the times, direct light only renderings.
Posted: Sat Jul 10, 2021 11:04 am
Sharlybg wrote: Sat Jul 10, 2021 10:37 am
There are more settings:
# Higher is the max. depth and more effect RR settings will have
path.maxdepth = 32
# At what depth, RR will start to operate: lower is faster. Range [0, path.maxdepth]
path.russianroulette.depth = 3
# At what value, RR will start to operate: lower is faster. Range [0.0, 1.0]
path.russianroulette.cap = 0.5
Posted: Sat Jul 10, 2021 11:33 am
In my test i played with theses two setting
"path.russianroulette.cap": 0.5,
"path.russianroulette.depth": 1,
So basically the default RR setting are Ok.
IS there a settings inside Lux we can manipulate to trigger this Cycles behaviour so that we make obvious the unfairness of the Benchmark.
I don't know something that cut off indirect light internally as we suppose cycles do.
Posted: Sat Jul 10, 2021 1:02 pm
Sharlybg wrote: Sat Jul 10, 2021 11:33 am
No, we don't bias if not explicitly told and only in very few cases (Cycles is exactly the opposite).
