Hi Dade,
when do you plan to publish a new release compatible with Blender version 3.1, and Python 3.10, of the BlendLuxCore add-on?
Thank you.
Thank you.
latest BlendLuxCore daily 2.61alpha is compatible with 3.1 and up to 3.3alpha... what givesHarvester wrote: Fri May 13, 2022 3:04 pm Hi Dade,
Thank you.
Have a look here:Harvester wrote: Fri May 13, 2022 3:04 pm Hi Dade,
Thank you.
https://github.com/LuxCoreRender/BlendL ... tag/latest
AFAIK won't work with 3.2 but should cover all the 3.1.x
Thank you all for your feedback. I did follow the instructions I found in the daily builds and I can confirm that it works with Blender 3.1.2.
I will continue to test it while waiting for an official release.
It works with every Blender using Python API 3.10.
Although, it's waiting for few pull requests to get in:
- Fix Pointer node
- Update to Fresnel node's custom n,k-values
- clarify readme on blender support status
https://github.com/LuxCoreRender/BlendLuxCore/pulls
- Fix Pointer node
- Odilkhan Yakubov
My own repo for Windows users with latest commits:
https://github.com/odil24/BlendLuxCore/ ... tag/v2.62a
- Odilkhan Yakubov
New version is up:
https://github.com/odil24/BlendLuxCore/ ... g/v2.62.1a
it will be more convenient if you send a pull from your repo to the original repository, so it will be merged with it at the end.
- Odilkhan Yakubov
Latest Blender v3.5a (https://builder.blender.org/download/da ... elease.zip) works with BlendLuxCore v2.62.1a (https://github.com/odil24/BlendLuxCore/ ... g/v2.62.1a) for now!!!
- Odilkhan Yakubov
Latest Official BlendLuxCore v2.61 is out:
