A baking test scene
				nestanqueiro
Re: A baking test scene
Thanks, how could I have missed that... I guess I went looking for the options in an earlier build I had at home, after reading about it at work, where I was testing baking...
I have added the support for transparencies and shadowcatcher to BAKECPU: https://skfb.ly/6QoxX
that's really nice. Well done.
That is great ! it is something I need to study to do in lux. It offer some possibility for interior archvizDade wrote: Tue May 05, 2020 12:07 pm I have added the support for denoising baked light maps with Intel ODIN (i.e. the new OIDN v1.1 feature).
Note: BAKECPU is not exposed in BlendLuxCore. This stuff is currently used only by https://www.vectary.com
If I use only luxcoreui, should I manually apply "denoise" to baked maps using OIDN (denoise.exe)?Note: BAKECPU is not exposed in BlendLuxCore. This stuff is currently used only by https://www.vectary.com
You can define an image pipeline in the .cfg including OIDN, like: https://github.com/LuxCoreRender/LuxCor ... ke.cfg#L39zuljin3d wrote: Sat May 16, 2020 1:55 pmDade wrote: Tue May 05, 2020 12:07 pm I have added the support for denoising baked light maps with Intel ODIN (i.e. the new OIDN v1.1 feature).If I use only luxcoreui, should I manually apply "denoise" to baked maps using OIDN (denoise.exe)?Note: BAKECPU is not exposed in BlendLuxCore. This stuff is currently used only by https://www.vectary.com
Thanks a lot Dade, it works!
I am new to LuxCore.
Could someone explain to me how I can get the light information baked to a texture for realtime graphics?
I already managed to set up everything in Blender
Kind regards
Kind regards
