cannot see reflection of light spot
strawman
Re: cannot see reflection of light spot
Post by strawman »
Dade, can you offer any further help? Can I somehow get volume scattering with path engine? I need the path engine for SDS but would also like to get volume scattering.
strawman wrote: Mon Dec 28, 2020 11:08 pm Dade, can you offer any further help? Can I somehow get volume scattering with path engine? I need the path engine for SDS but would also like to get volume scattering.
Can you show a reference image of what you to achieve. So that maybe i can help ?
strawman
Post by strawman »
Thanks for your offer to help.
The original image in this thread, made with "bidir", shows a beam being scattered as it travels through the volume (good). It is missing reflections in the mirrors (bad) as shown in the annotations.
Switching to "path" I can see the reflections in the mirrors (good) but no more beam scattering through the volume (bad).
The question is how to get both.
here is what i get (light tracing don't help alot here so it is disable) with path tracing and caustic cache.
moving-mirror7.blend
(1.07 MiB) Downloaded 803 times
strawman
Post by strawman »
Thank you. However, I forgot to mention in my previous post that the scattering should also be visible after the mirror. In your render, it is missing, whereas in the first post it is present.
Sharlybg, you have probably not set the exterior volume of all objects involved.
strawman
Post by strawman »
Dade wrote: Tue Dec 29, 2020 5:18 pm Sharlybg, you have probably not set the exterior volume of all objects involved.
I went ahead and added homogeneous external volume to all materials in the scene and I still don't see scattering below the mirror.
lighting_freak
Post by lighting_freak »
Hello all,
This seems to be interesting topic? Do we have any final resolution or explanation?
With what kind of settings or scene restrictions might this scene becomes renderable and shows the spots as well as the beam images in the mirrors?
Thank you.
BR
OS - Windows 7 X64
CPU - Intel CORE i7
