Page 2 of 2
Re: Histogram-preserving Blending for Randomized Texture Tiling (aka Procedural stochastic texturing)
Posted: Thu Aug 27, 2020 9:15 pm
I credited the right paper but the wrong author. I was assuming the author of the WebGL demo was the same of the paper.
Posted: Thu Aug 27, 2020 9:23 pm
by Rsharma
Dade wrote: Thu Aug 27, 2020 9:15 pm
Thank you for fixing it! Great implementation btw!
Posted: Thu Aug 27, 2020 9:35 pm
kintuX wrote: Thu Aug 27, 2020 4:45 pm
BTW
Are there any plans for custom controls like U&V offset, rotation & scale, amount and type of blending?
Here's corona's version for example
I'm not sure if they can be of any real use or just clutter the UI. Our current defaults (Randomize tiles on, 3 tiles, high quality blending, exponential blending) should be good for all seasons. Did you find some alternatively useful setup ?
Posted: Fri Aug 28, 2020 2:33 pm
by AndreasResch
Good looking and a necessary addition.
BTW
Count me in for that. This would be amazing and add so much more variance to scenes if necessary. In Blender I use UV randomization all the time. This and the Bevel Shader (which I see you are already working on) would be awesome improvements.
Posted: Fri Aug 28, 2020 2:40 pm
by AndreasResch
Dade wrote: Thu Aug 27, 2020 9:35 pm
BTW
Here's an example where randomized UV rotation comes in very handy. This are instances of the same object (same material of course) and all the wood grain is oriented differently, as it is in real life. I sometimes have dozens of them in scenes and this variance makes all the difference.
Posted: Fri Aug 28, 2020 3:11 pm
AndreasResch wrote: Fri Aug 28, 2020 2:40 pm
Ok but I was talking of the "Tiling" section of the UI panel: Randomized UV and Randomized Tiling are somewhat 2 separate and uncorrelated topics.
Posted: Fri Aug 28, 2020 3:20 pm
by AndreasResch
Dade wrote: Fri Aug 28, 2020 3:11 pm
I understand. But if you look at that Randomization dialog from Corona, it has a randomize option for the W axis. So with 1 tile and W randomization turned on, you will get the same result, right? Having some randomization in the Triplanar Mapping node would do the job as well.
Posted: Sun Aug 30, 2020 12:13 pm
The support for CPUs and GPUs rendering should be now complete.
Posted: Sun Aug 30, 2020 3:35 pm
Dade wrote: Sun Aug 30, 2020 12:13 pm
Awesome
Posted: Tue Apr 06, 2021 3:17 pm
by kintuX
Heads up... tools are available in a web browser.
source:
https://twitter.com/i/status/1318566180546879489
Tool to
Make your texture tileable with histogram-preserving blending
"Disclaimer: this is a CPU implementation that runs in javascript. The GPU implementation presented in the paper is orders of magnitude faster. "
So yeah, thanks again to everyone involved in implementing it!
