Side note: some of the Lacilaci's scene setting is a bit extreme at the moment; for instance, I have yet to implement Russian Roulette on photon paths, this mean the pre-processing code wastes a lot of time tracing photon paths carrying nearly zero light. RR greatly speedup this kind of stuff. Also using matte, instead of glossy, for the walls can speedup the rendering too.
Dade wrote: Fri Feb 08, 2019 8:09 pm
Speedup would be welcome.
Although using matte for walls might be faster, glossy with bump and mapped roughness would be more realistic.
However!
Maybe a rayswitch for GI rays could be a solution.
Maybe photonGI could internally calculate GI as if all materials are matte, but render as usual?
lacilaci wrote: Fri Feb 08, 2019 8:22 pm
It is possible but it is a LOT of bias. I'm a bit more comfortable with the idea of leaving the option to choose (between glossy walls vs matte walls) to the end user.
Note: I was talking of pre-processing speed, for the rendering speed is all pre-computed so it doesn't matter.
I understand. I think what I requested could be achieved in future with a rayswitch material.
