LuxCoreRender v2.1beta2 released
Beta2 released
New LuxCoreRender v2.1beta2 release is available.
v2.1 release notes are available here: https://wiki.luxcorerender.org/LuxCoreR ... Notes_v2.1
LuxCore bug fixes:
  • Updated Embree v3.2.4 (no more Intel C++ run-time DLLs required)
  • Fixed a problem with DLSC now uses shading normal instead of geometry one
  • Fixed an inconsistency in normal (geometry Vs shade) used triangle lights
  • Fixed sky2 direct light sampling (i.e. the sky was flipped upside down)
  • DLSC will now use not less than 512 samples for all env. light sources
  • Fixed a bug in bump mapping code when using UV rotations
BlendLuxCore new features:
  • Show a warning if all light groups are disabled
BlendLuxCore fixes:
  • Fix area lights emitting light on the wrong side when a negative scale is used
  • Fix cloth material's repeat parameters being exposed as sockets instead of scalars
  • Fix regression introduced in Alpha4 where CPU was not being used during OpenCL renders
  • Fix bug in motion blur export of shared meshes (issue #206)
LuxCoreRender v2.1beta2 files
BlendLuxCore is available here: https://github.com/LuxCoreRender/BlendL ... _v2.1beta2
Standalone LuxCoreRender is available here: https://github.com/LuxCoreRender/LuxCor ... _v2.1beta2
VisualStudio 2017 builds
NOTE: Thanks to Acasta69 work, this release for Windows is compiled with VisualStudio 2017. You may need to install the VS2017 runtime libraries: https://support.microsoft.com/en-us/hel ... -downloads
Egert_Kanep
Re: LuxCoreRender v2.1beta2 released
Post by Egert_Kanep »
Some neat fixes this time, thanks guys! Especially the motion blur fix, more flexibility for animation rendering.
Racleborg
Post by Racleborg »
Many thanks again for all the hard work that goes into this fabulous software.
Dez!
Post by Dez! »
Wow, Serious Update
marcatore
Post by marcatore »
Thank you guys.
yesterday I had a full-day use with last beta and it worked well.
Post by FarbigeWelt »
Thank you for beta2.
Particles Fireworks
Particles Fireworks
