Problem with bump map
Re: Problem with bump map
Dade wrote: Mon Nov 12, 2018 9:18 am What ?!?!
I was looking at the "90" Vs. "90.000002504478161" and I wasn't seeing the ".uvrotation" Vs. ".rotation" :roll:
Fixed. So this explain the difference between inside/outside Blender.
Ok, I should have fixed the bump mapping problem too. The UV rotation was applied in absolute coord. space so the shading bump effect was rotated too.
The daily build available in a couple of hours will include the fix.
