Dez! wrote: ↑Fri Sep 28, 2018 2:03 pm
Thank you. disabling bloom, I got the Alpha 4 job.
but I need bloom.
Try to disable film OpenCL image pipeline and just switch film CPU image pipeline (I think B.Y.O.B. has added the support for this option to BlendLuxCore). It should work around the problem.
problem with the denoise remained. he kills the gloss.
Tomorrow, I will check this problem.
Dade wrote: ↑Fri Sep 28, 2018 4:19 pm
Yes, the option is in the imagepipeline settings (camera properties), next to the transparent film option.
I understand the answer correctly?
you can animation from the blender to export to the Standalone version of Luxrender.
and there are no problems with the denoiser in it.
Linux Plasma | Ryzen 5, 32Gb, SSD M2, GT 590 RX | BenQ 27 | Wacom One | Microsoft Ergo | Tie Guan Yin tea http://dezigner.tilda.ws/
after joyful jumped 5 minutes I continued to explore the problem
it turns out, it's not in Hemi
it turns out, the fact is that there is no World HDR in the scene. And there are only Hemi.
If the scene is lit World HDR, everything is fine
