cannot activate lux render
centauri
Re: cannot activate lux render
Post by centauri »
I have got the same problem here.
Considering your suggestions:
I wouldn't know of any python installation on my system. Python itself I never installed. Blender always worked without this, it is because there is a python version coming with the Blender package I guess.
Ok what else:
Re-Installing Blender, If i just use the zip version of Blender, doesnt make sence. But I deleted the complete configuration files instead and tried again.
I have a 64bit System and using the 64bit 2.79b Blender Version, freshly downloaded.
Also I installed the C++ Redistributable.
Other than that I could make Luxcorerender run on another system today and I am really, really impressed! This is a huge improvement over Luxrender, mostly I like the much better integration into blender & user friendliness.
Thanks for your support
You are getting the exact same error messages?
They are really weird, requests and urllib3 are modules that are included in the Python standard library, they are always available and should work.
centauri
Post by centauri »
Well, now that I checked in more detail, my error description is only similar. The first error is the same, the second one is different.
File "C:\Program Files\Blender Foundation\Blender\2.79\scripts\modules\addon_utils.py", line 331, in enable
mod = __import__(module_name)
File "C:\Users\secret\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\__init__.py", line 13, in <module>
from .bin import.pyloxcore
ImportError: DLL load failed: Das angegebene Modul wurde nicht gefunden.
so there is no problem with the modules "requests" and "urllib3", rather it seems like it tries to import a module that is not specified (module_name)
centauri wrote: Tue Sep 25, 2018 4:50 pm Traceback (most recent call last):
Ok so pyluxcore fails to load (although I find it weird that it says "pyloxcore", with an "o" instead of "u"?).
Which version do you try to install?
If it's v2.1alpha3, you also need the intel redistributable: https://software.intel.com/sites/defaul ... .3.210.zip
Also, just to make sure, you have downloaded the correct zip package for your system from the release section, right?
https://github.com/LuxCoreRender/BlendLuxCore/releases
You can not combine the latest BlendLuxCore sources with outdated LuxCore binaries (you would have to recompile them).
Just in case you tried using the latest BlendLuxCore sources.
centauri wrote: Tue Sep 25, 2018 4:04 pm Other than that I could make Luxcorerender run on another system today and I am really, really impressed! This is a huge improvement over Luxrender, mostly I like the much better integration into blender & user friendliness.
Thanks for the positive feedback, glad to hear that :)
Back on topic: which system was this exactly, why did it work there an not on your other system?
centauri
Post by centauri »
B.Y.O.B. wrote: Tue Sep 25, 2018 5:43 pm Ok so pyluxcore fails to load (although I find it weird that it says "pyloxcore", with an "o" instead of "u"?).
Sorry, again my bad! I just typed it out manually and it is saying "pyluxcore" of course. I dont want to cause more confusion :lol:
B.Y.O.B. wrote: Tue Sep 25, 2018 5:43 pm Which version do you try to install?
I took the official download which is there called "BlendLuxCore-v2.0-win64-opencl"
I searched for the module and it is present here
...\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\bin\pyluxcore.pyd
please notice the ending *.pyd ... ? I changed it to *.py just to test it, but nope...
B.Y.O.B. wrote: Tue Sep 25, 2018 5:43 pm which system was this exactly, why did it work there an not on your other system?
Why did it work there? If I knew that I would fix it here :D ...the working system is a laptop with Windows 10, the non working is a desktop PC with Windows 10 as well
Can you try the latest alpha from https://github.com/LuxCoreRender/BlendLuxCore/releases?
(Don't forget the intel thing: https://software.intel.com/sites/defaul ... .3.210.zip)
And make sure you have installed the Visual C++ Redist. stuff: https://www.microsoft.com/en-US/downloa ... x?id=40784
Do you have the old LuxBlend installed?
It should not be active the same time as BlendLuxCore.
If it is active, deactivate it in the user preferences, then save user prefs and restart Blender, then activate BlendLuxCore.
That is correct, it's some kind of Python DLL file, not a normal .py file.
centauri
Post by centauri »
B.Y.O.B. wrote: Tue Sep 25, 2018 6:01 pm Can you try the latest alpha from https://github.com/LuxCoreRender/BlendLuxCore/releases?
both installed. same error with 2.1 alpha.
Old Lux removed too. As I have writte earlier, I also tried removing all stuff from the local app path. That should do the same.
centauri
Post by centauri »
Ok so I googled again. This guy seems to have had the same problem and found a workaround by putting the OpenCL path in his System Variables list into quotation marks (because the path contained a spaces).
https://github.com/LuxCoreRender/BlendL ... issues/138
So I checked my System Variables too but I had no such OpenCL path. Why could this be? Is there another installation required? OpenCL with Luxrender worked well before.
Ok at least that brought me to the idea to try the non-OpenCL version and voila, that one can be activated and renders smoothly!
but of course in the future i would like to try the OpenCL version!
Had similar OCL issues here with few NVidia drivers. IIRC, between versions 377 and 391 were broken.
Try LuxMark to see if your OpenCL installation is working correctly.
Maybe try to reinstall/update your graphics driver.
