it works
Luxcore 2.1 Benchmark
Re: Luxcore 2.1 Benchmark
It works now, thank you!
Nevertheless I have a warning:
Material "Glassxgo green": 'bpy_prop_collection[key]: key "Gamma" not found'
Damnit, I forgot one (I guess this only happens in viewport render?)
I'll fix it later.
Anyway, to fix it, you just have to create a new imagemap node, select the same image as on the old node, rewire everything and delete the old node.
I'll fix it later.
I guess, the error didn't pop-up with f12 but viewport rendering triggered itB.Y.O.B. wrote: Wed Sep 12, 2018 2:30 pm Damnit, I forgot one (I guess this only happens in viewport render?)
I'll fix it later.
Yes, you're right.
I can live with that warning.B.Y.O.B. wrote: Wed Sep 12, 2018 2:30 pm Anyway, to fix it, you just have to create a new imagemap node, select the same image as on the old node, rewire everything and delete the old node.
(Don't wanna go through all the materials...)
CPU (Xeon E5-1650 @3,5Ghz) = 42'58"
GPU Quadro k5200 + CPU = about 11' . I had a problem with the rendering, during the rendering phase the preview was ok, when render finished, the image was completely white.
The warning tells you the name of the material. Just pin the material node tree in node editor, then search for the material name in the node editor's tree selection dropdown.
Sounds like the image is screwed up during the compositing stage?marcatore wrote: Thu Sep 13, 2018 8:42 am during the rendering phase the preview was ok, when render finished, the image was completely white.
OK, thanksB.Y.O.B. wrote: Thu Sep 13, 2018 8:46 am The warning tells you the name of the material. Just pin the material node tree in node editor, then search for the material name in the node editor's tree selection dropdown.
jensverwiebe
- Supporting Users
Same happens here randomly on linux Mint 19 and NVidia ( 2 x gtx 1080 + gtx 980ti ) as well as on macOS 10.12 NVidia ( amd 7970 + gtx 980 webdriver ).marcatore wrote: Thu Sep 13, 2018 8:42 am [snip] I had a problem with the rendering, during the rendering phase the preview was ok, when render finished, the image was completely white.[/snip]
Switching to non-opencl imagepipeline did not help. No idea atm. what triggers this, but the renderlayer vs. composite is okay.
EDIT1: Found that oddly sometimes the compositor node connection from renderlayer to the colorbalance node gets lost
EDIT2: Aah, could be a test error from myself, i disabled denoise for faster seeing the result, so this slot is gone aka connection gets lost.
-> user error, marcatore, can you confirm you did same ?
EDIT3: checked over, the white composite comes from disabling denoise, one must reconnect the renderlayer with plain color output then
( or reenable denoise )
So, false alarm, mea culpa.
Jens
4 min, 46 sec on four 7950's.
