I'm testing the new light strategy.
I got this warning in the log:
[LuxCore][4031.706] WARNING: direct light sampling cache hit rate is not good en
ough: 80.2728%
What should I do to increase the hit rate?
Direct Light cache: hit rate not good
Re: Direct Light cache: hit rate not good
The code will add entries, to the cache up, to when the threshold hit rate (lightstrategy.targetcachehitratio, default 99.5%) is met or the maximum samples count is reached (lightstrategy.maxsamplescount, default 10,000,000).marcatore wrote: Mon Jul 02, 2018 8:19 am I'm testing the new light strategy.
ough: 80.2728%
So he most direct way to increase the cache hit rate (by increasing the number of cache entries) is to increase the maximum samples count.
There few other less direct (on more debatable) ways:
- decrease the max. path depth (lightstrategy.maxdepth, default 4);
- increase the cache entry radius (lightstrategy.entry.radius, default 0.15);
Are you rendering an open scene ? Can you post a rendering of the scene to have an idea of what we are talking about ?
"Are you rendering an open scene ? Can you post a rendering of the scene to have an idea of what we are talking about ?"
The scene is this Completed in 7m23sec
Some reports with this scene:
- 82 area lights from the lights projector + sun outside
- the default cache samples number is probably too high because it calculate cache forever...it's really really slow and after 15 minutes I closed blender. That image is rendered with 6000 max samples and it took about 3 minutes to calculate lightcache.
- I've also decreased the max depth to 1.
- the entry radius is 30cm
- I haven't touched any other lightcache setting
- I'm using CPU path render with total depth of 10, diffuse 10, glossy 10 and specular 10
- Output clamped to 1500
- Sampler to Sobol with 0.7 as adaptive strenght
- Rendering Halt condition 150 samples
This is the same scene, just with Log Power instead Direct Lightcache completed in 3min39sec
Your area lights are made of how many triangles ?
Your light cache is likely to be nearly empty. There is a lot of space between 6,000 and 10,000,0000.marcatore wrote: Mon Jul 02, 2018 9:46 am - the default cache samples number is probably too high because it calculate cache forever...it's really really slow and after 15 minutes I closed blender. That image is rendered with 6000 max samples and it took about 3 minutes to calculate lightcache.
But if you are getting a 3min pre-processing for 6,000 samples, there must be something wrong, what CPU do you have ? Windows ?
It is too small, try 3 or just use the default value 4.
Note: I have the feeling, your scene is lighted only by sun + indirect illumination, can you try the same test without the sun ?
Area lights are the standard Blender "area light" object. I don't know how many triangles has, I imagine it's a simple plane, so it should be 2 triangles.
My CPU is Xeon E5-1650 v3 @ 3.5Ghz, 16Gb Ram. Windows 7 64bit
This is a render without sun&sky and with path depths set to 1 (total depth, diffuse, glossy and specular to 1)
But how is the difference between cache On Vs. Off in this case ?marcatore wrote: Mon Jul 02, 2018 10:57 am This is a render without sun&sky and with path depths set to 1 (total depth, diffuse, glossy and specular to 1)
The "circles" and "the dirty patches" (i.e. high noise) you see on some wall, is exactly the result of "not enough cache entries".
When do you ask me about "the difference", are you speaking visual difference or in term of rendertimes?
In any case, about visual, this is the same render with Log Power light strategy.
The difference is huge as expected but you are still using only 6,000 samples, right ?marcatore wrote: Mon Jul 02, 2018 12:19 pm In any case, about visual, this is the same render with Log Power light strategy.
Yes. I'm still using 6000.
And actually the direct lighting has a lot less noise
About the few samples I'm using...it seems you're quite surprised to see that I can use only so few samples (and I'm surprised too considering that the default is quite higher). Have you got an idea about this?
