LuxCoreRender v2.1alpha0 released
Re: LuxCoreRender v2.1alpha0 released
Hi thanks you for this amazing soft :D !
Just testing v2.1 alpha0. Is there possibility to add text to explain each denoiser setting when the mouse cursor is on a setting box. :
something like :
increase this value reduce blur
reduce this value to preserve detail
increase value mostly in case you render in high resolution 2k / 4k
Also can you provide us a pyluxcore updated to solve black viewport preview :mrgreen:
Tooltips will be added.
Sharlybg wrote: Fri May 18, 2018 4:05 pm Also can you provide us a pyluxcore updated to solve black viewport preview
Was this bug already reported? Can't remember it.
Thanks B.Y.O.B !
Yes and it seem you already fix it : ( i've currently a black material preview ) (edit sorry want to say material preview in my previous post :mrgreen: )
FiatLux wrote: Sat May 12, 2018 5:00 pm 1) Material preview doesn't work anymore to me (All black and laggy).
Is it the same for you?
This is the error from console:
Thanks for the report, I fixed it.
Nothing to help fix material preview before another release ? ;)
Sharlybg wrote: Tue May 22, 2018 3:24 pm Nothing to help fix material preview before another release ? ;)
You can patch in the fix yourself: https://github.com/LuxCoreRender/BlendL ... 2f06ec5000
In your BlendLuxcore installation, go to the folder "engine", open the file "preview.py" in a text editor and change the lines that are highlighted in the commit.
Red is the old line, green the new line.
E.g. in line 60, you should replace
engine.framebuffer.draw(engine, engine.session, scene)
with
engine.framebuffer.draw(engine, engine.session, scene, False)
B.Y.O.B. wrote: Tue May 22, 2018 5:37 pm
with
What a gift :D thank you B.Y.O.B. you give me not only the fix but also the will to learn programing again(python) :mrgreen:
It work great : just change the file extensions to .py after you download and paste it in the blendluxcore installation folder
preview.blend
(12.65 KiB) Downloaded 1139 times
Odilkhan Yakubov
Post by Odilkhan Yakubov »
Hello. I downloaded latest version with Denoiser, but don't understand how to using. Just a little bit confused.
I mentioned the necessary steps here: viewtopic.php?f=9&t=335#p3884
Which point is not clear?
Odilkhan Yakubov
Ive done as you mentioned but nothing denoised.
1. I start render
2. Rendered first samples
3. Run the denoiser
4. Select pass Denoised and there is just black blank
4. Nothing happen just show the rendering on progress bar and show: Denoising...Expacted: secs(last:unknown)
The image will stay black until the denoising process finish the job !
