Metal Material
david57
Metal Material
Post by david57 »
I tried to use an NK file from this site:
http://luxpop.com/RefractiveIndexList.html
I tried the chrome "Cr.nk" file but luxCore didnt accept the file and could not use it.
Re: Metal Material
I can reproduce the problem.
luxpop_problem.zip
(1.6 MiB) Downloaded 1334 times
david57
Re: Metal Material
Post by david57 »
I tried the test scene you posted and got this error.
I dont have radeon prorender installed ?
david57
Re: Metal Material
Post by david57 »
I checked my addons and I had an old addon from radeon prorender. I removed it.
Im still having an error message.
Re: Metal Material
Yup, erroneous... didn't had much time to explore different standards in use... so for now,
this solution still applies.
Note:
Either .nk or .ior, use as Sopra. ;)
david57
Re: Metal Material
Post by david57 »
I just tried the site but the site is not working.
I searched for SOPRA files from the net and found one.
Maybe I can find more or convert LUXPOP files into SOPRA files by hand.
That site is here.
https://github.com/ulfgri/nk/blob/master/sopra/gaas.nk
david57
Re: Metal Material
Post by david57 »
Here is a long list of SOPRA files that I need to tryout :
https://github.com/ulfgri/nk/tree/master/sopra
Re: Metal Material
I did try those & none of them work out-of-the-box. Bad header and different description than expected so w/o a translator, they need to be adapted manually. And i have yet to dive deeper and discover what form is readable for LuxCoreRender.
david57
Re: Metal Material
Post by david57 »
Yes, I also got the error about a bad sopra header.
I cant figure it out.
david57
Re: Metal Material
Post by david57 »
Here is one I can use.
I found one for brass:
http://www.luxrender.net/forum/viewtopi ... 4&start=10
