Dispersion Tints Surfaces Red
Starjukker
Post by Starjukker »
Hello everyone!
This is an issue I've been encountering since I first started using Luxcore, and I believe I'm not the only one. The issue is, when using dispersion of any kind, it turns the surface red-ish, so glass and water becomes muddy and tinted. Can it be fixed or worked around?
Here are the examples of the same scene with and without dispersion.
Tumbler on Table1.zip
Blend file with the test scene
(780.81 KiB) Downloaded 5839 times
