Productviz / Packshot by Juliano Lisboa
JulianoLisboa
Re: Productviz / Packshot by Juliano Lisboa
Post by JulianoLisboa »
Thank you friend, I forgot to thank you for the praise of Zupp's work.
JulianoLisboa
Reviews are always welcome
Martini
Post by Martini »
JulianoLisboa wrote: Fri May 20, 2022 1:50 pm Reviews are always welcome
I do love how you can see through the little tube that goes up to the top :D but should that be full with liquid?
It looks like you have not set enough light bounces - can I recommend setting everything except Diffuse to at least 32? This will remove/reduce the black edges on the glass, which IMO detracts from the realism because it is quite characteristic of a render with not enough light bounces. It might also change the super dark shadow on the box at the back.
If you had time I'd also love to see a version with BiDir or Light Tracing and/or PhotonGI Caustic enabled :)
Luximage
Post by Luximage »
Excellent render visualization Juliano!
