JulianoLisboa
Post by JulianoLisboa »
Hi, when will we have a working build in Blender 3.0?
BlairKnox
Post by BlairKnox »
Just checking. Does the BlendLuxCore latest build (pre-release) work for blender v3.0
BlairKnox wrote: Thu Dec 30, 2021 2:47 pm Just checking. Does the BlendLuxCore latest build (pre-release) work for blender v3.0
I think not yet.
The next, under compilation, build should work fine with Blender v3.0. The source of the problem is a broken NumPy version used to compile Blender.
We have a workaround for that problem but it required to rollback a patch for a minor bug. It should effect only people exporting scene in text format for LuxCoreUI: viewtopic.php?f=4&t=3505
We will look for a different solution of the original problem too (one that doesn't trigger the broken Blender v3.0 NumPy).
JulianoLisboa
Dade wrote: Thu Jan 06, 2022 12:25 pm The next, under compilation, build should work fine with Blender v3.0. The source of the problem is a broken NumPy version used to compile Blender.
Very good Dade, looking forward to it. Thanks
MCurto
Post by MCurto »
I think there might be a slight problem with GitHub linux version for latest build 2.6.1, i've tried in Fedora/Blender 3.0 and doesn't seem to be working, funny thing is the one I compiled does work: :)
https://drive.google.com/file/d/1c64NPb ... sp=sharing
marcbartels
Post by marcbartels »
MCurto wrote: Sat Jan 08, 2022 5:15 pm I think there might be a slight problem with GitHub linux version for latest build 2.6.1, i've tried in Fedora/Blender 3.0 and doesn't seem to be working, funny thing is the one I compiled does work: :)
I can confirm this is working, but the daily build is not.
Using Manjaro and Blender 3.0
Actually, LuxCore has always worked with Blender v3.0 on Linux, it was a Windows-only problem. I have downloaded the latest build and tried with Blender v3.0 on my Linux Ubuntu and it is working fine for me.
What kind of problem do you have ? A crash ? Is Blender v2.93+BlendLuxCore working ?
Dez!
Post by Dez! »
I can confirm that ElementaryOS has been running smoothly around the clock. I've been using it in Blender 3 since January 4.
marcbartels
It is working correctly on Blender 2.93.
In Blender 3.0 on enabling the addon this error occurs:
Making LuxCore denoiser executable
  File "/usr/share/blender/3.0/scripts/modules/addon_utils.py", line 351, in enable
    mod = __import__(module_name)
  File "/home/marc/.config/blender/3.0/scripts/addons/BlendLuxCore/__init__.py", line 66, in <module>
Exception:
Could not import pyluxcore.
ImportError: /home/marc/.config/blender/3.0/scripts/addons/BlendLuxCore/bin/pyluxcore.so: undefined symbol: _PyTraceMalloc_NewReference
