The pink elefant
The pink elefant
Post by Dade » Sun Dec 31, 2017 10:44 am
Spectral rendering done in LuxCore :o
(who is used to old LuxRender renderings can easily spot the rainbow-ish white on early stage of the rendering)
This is just the result of a test (direct light only) to check if the general idea can work. I think it is worth some further investigation. It would be the perfect solution:
- it is optional (no cost for normal RGB rendering);
- it does require very little code changes;
- it works on GPUs;
- it works with path, bidir and everything else.
P.S. The pink elephant is a quote from: http://www.luxrender.net/forum/viewtopi ... =8&t=12454
Supporting Users
Re: The pink elefant
Post by Sharlybg » Sun Dec 31, 2017 1:27 pm
- it works on GPUs;
Wow incredible move ! thanks you so much for sharing such juicy news with us. can't wait to see more screenshots with this (indirect light/ glass render). But take your time. with such great features it's worth to be patient. :D .
the pink elephant is going to be a small white mouse in your labs :lol:
Piita
Supporting Users
Post by Piita » Sun Dec 31, 2017 3:15 pm
Ah, spectral, old friend. I missed you. You do require a lot of render time in order to look good but when you are done you sure are gorgeous :)
Awesome work, Dade!
neo2068
Post by neo2068 » Sun Dec 31, 2017 6:25 pm
:o wow, great news. Looking forward for next year development. 😊
i7 5820K, 32 GB RAM, NVIDIA Geforce GTX 1080 + GTX 780, Windows 10 64bit, Blender 2.79b
Post by Dade » Mon Jan 01, 2018 10:57 am
Normal rendering (BIDIRCPU):
Spectral rendering (BIDIRCPU):
:lol: :lol: :lol:
P.S. at the moment, I'm not even sure if it is theoretically correct, for sure, it is damn good at faking it.
Post by Dade » Mon Jan 01, 2018 12:08 pm
Supporting Users
Post by Sharlybg » Mon Jan 01, 2018 11:01 pm
:shock: :shock: wow it is very very beautifull and very real. And i also think it is a very well integrated code. I ve never seen this before with a renderer ( the possible to activate and desactivate spectral rendering on the fly). Bravo .
Post by Dade » Tue Jan 02, 2018 11:30 am
Added the support glass dispersion on GPUs:
I have merged the experimental branch with the main one.
Glass dispersion can be enabled using the ".dispersion" flag in Glass material definition. Volumes/Glass IORs can now accept 3 values instead of 1 (red IOR, green IOR, blue IOR). For instance:
scene.materials.Cubo_Prism_01_MAT.type = glass
scene.materials.Cubo_Prism_01_MAT.kr = 1. 1. 1.
scene.materials.Cubo_Prism_01_MAT.kt = 0.8 0.8 0.8
scene.materials.Cubo_Prism_01_MAT.ioroutside = 1.0 1.0 1.0
scene.materials.Cubo_Prism_01_MAT.iorinside = 1.28 1.4 1.52
scene.materials.Cubo_Prism_01_MAT.dispersion = 1
P.S. you can still use a single value for IORs (but indeed there will be not dispersion).
Post by B.Y.O.B. » Tue Jan 02, 2018 3:50 pm
This is pretty cool.
It's not even much slower than without dispersion, both attached images were rendered for 16 minutes.
How should we expose this in exporters?
Should we allow the user to set 3 separate values?
Or would it be better to have only one IOR-value in the UI and have a "Dispersion Strength"-slider which specifies the diverting IORs?
For example:
IOR: 1.5
Dispersion Strength: 0.02
-> exported as iorinside = 1.48 1.5 1.52
By the way, I'm getting a crash when using Tiled Path + dispersion when I stop the render.
Post by Dade » Tue Jan 02, 2018 5:08 pm
For example:
IOR: 1.5
The "strength" solution sounds a lot easier to use (and more artist oriented).
I could potentially add, in the future, the support for tabulated texture in order to potentially have a different IOR for each visible wave length (at the moment, the IOR is just interpolated between the 3 RGB wave lengths). But it is frankly the kind of feature that 99.999999999% of Blender users are never going to use.
Uh, I never tried with TILEPATH, strange, going to check ... it doesn't seems to happen here (it may be a different problem, not related to dispersion), can you post how reproduce the problem.
