OIDN new version Out
Re: OIDN new version Out
maybe it doesn't work in 2.83 blender version
The problem seems to be 2.83 here. In 2.83 it doesn't work for me neither. It does in 2.91 and 2.92.
Yep, I confirm on 2.92 everything works fine, thanksAndreasResch wrote: ↑Tue Mar 09, 2021 1:38 pm The problem seems to be 2.83 here. In 2.83 it doesn't work for me neither. It does in 2.91 and 2.92.
1.3 oidn is impressive!
Now there is no problem with blurred areas on some textures with details
I agree. The difference is obvious.
Strange, working fine in 2.83.12 LTS, 2.91.2 & 2.92 (same addon distributed to blender version respective foolders)AndreasResch wrote: ↑Tue Mar 09, 2021 1:38 pm The problem seems to be 2.83 here. In 2.83 it doesn't work for me neither. It does in 2.91 and 2.92.
IME also, OIDN 1.3 results are best compared to other denoisers now.
I notice you still have tbbmalloc.dll, can you try deleting that?
Also your OpenImageIO.dll is named OpenImageIO_LuxCore.dll
That should be ok, we have renamed the library in Windows builds to avoid some compatibility issues for the 3dsMax plugin.
