Hello,
There is probably something fundamental I am not understanding but when I drag an item from the bar to the scene I get the following error.
I have tried uninstalling and reinstalling blender but no change.
Thanks
Python: Traceback (most recent call last):
File "C:\Users\YYY\AppData\Roaming\Blender Foundation\Blender\2.91\scripts\addons\BlendLuxCore\operators\lol\assetbar.py", line 917, in modal
context, mx, my)
File "C:\Users\YYY\AppData\Roaming\Blender Foundation\Blender\2.91\scripts\addons\BlendLuxCore\draw\lol\viewport.py", line 393, in mouse_raycast
bpy.context.view_layer, ray_origin, vec)
TypeError: Scene.ray_cast(): error with argument 1, "depsgraph" - Function.depsgraph expected a Depsgraph type, not ViewLayer
Getting a error when attempting to use the LuxCore online Library
Re: Getting a error when attempting to use the LuxCore online Library
That happens to me too on Blender 2.91.2, but it works fine on Blender 2.83.12. I think it means that the Blender developers changed something with the latest API version that isn't compatible with the way drag & drop works for this addon.
You can work around the issue for now, by clicking exactly (don't drag) on the thumbnail you want to import. Make sure to keep the mouse perfectly still, and it will import correctly at the location of the 3D cursor.
Thanks Martini, you're a scholar and a mensch.Martini wrote: Wed Feb 10, 2021 11:22 am That happens to me too on Blender 2.91.2, but it works fine on Blender 2.83.12. I think it means that the Blender developers changed something with the latest API version that isn't compatible with the way drag & drop works for this addon.
Well... it turns out, the fix for this problem was pretty easy... so... I also fixed the problem...
Here is the pull request: https://github.com/LuxCoreRender/BlendLuxCore/pull/629
@B.Y.O.B.
Hi @Mercury, you can find the fix in the latest daily build here: https://github.com/LuxCoreRender/BlendLuxCore/releasesMartini wrote: Wed Feb 10, 2021 2:21 pmWell... it turns out, the fix for this problem was pretty easy... so... I also fixed the problem...
samlarsoonn
YesHi @Mercury, you can find the fix in the latest daily build here: https://github.com/LuxCoreRender/BlendLuxCore/releaseswrote:Well... it turns out, the fix for this problem was pretty easy... so... I also fixed the problem...Thanks Martini, you're a scholar and a mensch.
with the latest 2.5 they finally completely solved this issue
Hi there
