No, not yet.
first steps on luxcore
Re: first steps on luxcore
Hi!
here the author in 1.7 version makes the material "white glass"
https://youtu.be/GpvHYi8uW1Y?t=28m32s
In the new version 2.0 interface, and the node has changed, and I can't repeat the material.
The author uses material "Glass 2" which is no more. I assumed that all combined in just the glass.
At the end of the development of the material, the author reduces some transparency:
I assumed tepere this transparency made here:
Is to reduce it, as the objects had no modificator Subsurf become visible edge of the polygon:
PS: where can I download this test scene?
PS2: In conclusion, allow me to thank You for the excellent render!
I was very impressed with the results of the author's video lessons with beer bottles and interior. I'm inspired!
Now you are in the list of those who I make a Donat
Yes, just use glass. If you attach an interior volume it behaves like the old glass2 (using the volume IOR).Dez! wrote: Sun Apr 08, 2018 1:34 am In the new version 2.0 interface, and the node has changed, and I can't repeat the material.
Yes, however the new opacity is much faster than the old alpha transparency.Dez! wrote: Sun Apr 08, 2018 1:34 am At the end of the development of the material, the author reduces some transparency:
Smooth shading is a trick that only works with mesh surfaces. What you see in your image is the volume contained within the mesh - it just looks like a solid surface because of the high scattering scale. Shooth shading does not work on volumes, so you will have to subdivide the mesh more.Dez! wrote: Sun Apr 08, 2018 1:34 am Is to reduce it, as the objects had no modificator Subsurf become visible edge of the polygon:
We should add it to the test scene repository, but until then, here you go.
luxball_luxcore.blend.zip- (3.39 MiB) Downloaded 591 times
Thank you for the detailed answer
