It must be as you said, after deleting / restarting everything Optix is always found.
However I'm left with the first problem I described, i.e. crash before the render starts.
I'll be away from the GTX970 for some time, I'll give more info when I can test again.
Optix/RTX support
Re: Optix/RTX support
I moved my old GTX 980 to the new PC and the scene is not crashing on Linux but it is rendering nothing at all. I'm checking if it is a problem on our side because Optix is very slow in general on GTX 980 and should be probably not used.acasta69 wrote: Wed Aug 05, 2020 10:01 am It must be as you said, after deleting / restarting everything Optix is always found.
If I disable Optix (context.cuda.optix.enable=0) the scene works fine on the GTX980. This smell like a Optix problem on RTX-less GPUs.Dade wrote: Wed Aug 05, 2020 11:17 amI moved my old GTX 980 to the new PC and the scene is not crashing on Linux but it is rendering nothing at all. I'm checking if it is a problem on our side because Optix is very slow in general on GTX 980 and should be probably not used.acasta69 wrote: Wed Aug 05, 2020 10:01 am It must be as you said, after deleting / restarting everything Optix is always found.
Thanks Dade, I'll do the same test as soon as possible but it will take some days.Dade wrote: Wed Aug 05, 2020 11:51 am If I disable Optix (context.cuda.optix.enable=0) the scene works fine on the GTX980. This smell like a Optix problem on RTX-less GPUs.
I reworked the support for enabling/disabling/auto-selecting Optix/RTX.Dade wrote: Wed Aug 05, 2020 11:51 am If I disable Optix (context.cuda.optix.enable=0) the scene works fine on the GTX980. This smell like a Optix problem on RTX-less GPUs.
First, you can check if Optix is available, or not, by checking the "compile.LUXRAYS_ENABLE_OPTIX" property of luxcore::GetPlatformDesc().
Now, Optix/RTX will be used by default only on CUDA GPU with 7.5 compute capability or better (RTX cards). A list of all NVIDIA GPU CUDA compute capabilities can be found here: https://developer.nvidia.com/cuda-gpus
You can check the CUDA device compute capability by checking the properties "opencl.device.x.cuda.compute.major" and "opencl.device.x.cuda.compute.minor" (7 and 5 for RTX GPUs) of luxcore::GetOpenCLDeviceDescs().
You force-enable/force-disable/auto-select Optix/RTX for each CUDA GPU device using the "cuda.optix.devices.select" property. It works like "opencl.devices.select", there is a "0"/"1"/"A" to force-enable/force-disable/auto-select Optix/RTX.
NOTE: "cuda.optix.devices.select" has a char only for each single CUDA device available (nothing for OpenCL devices) so, with 1xOpenCL CPU+2xOpenCL GPUs+2xCUDA GPUs I can use the following settings:
# 3 OpenCL devices + 2 CUDA devices
opencl.devices.select = 10011
# only 2 CUDA device settings
cuda.optix.devices.select = 10
I assume now BlendLuxCore, should have an option for each (CUDA) device in the device list to force-enable/ force-disable/auto-select Optix/RTX.
The default should be "auto-select" and I don't see any reason to change that if not for testings.
- Odilkhan Yakubov
Hi. I finally installed Lux v2.5 latest on Blender 2.83 and used also Optix viewport denoiser. Is it possible to rendering using Optix denoiser not just in viewport but also on rendering too like in Cycles?
Yes, but it's not yet implemented in the Blender addon.Odilkhan Yakubov wrote: Tue Aug 18, 2020 8:40 pm Is it possible to rendering using Optix denoiser not just in viewport but also on rendering too like in Cycles?
- Odilkhan Yakubov
so is it in yours plans, am i right?B.Y.O.B. wrote: Tue Aug 18, 2020 8:41 pmYes, but it's not yet implemented in the Blender addon.Odilkhan Yakubov wrote: Tue Aug 18, 2020 8:40 pm Is it possible to rendering using Optix denoiser not just in viewport but also on rendering too like in Cycles?
