Texture view in Blender viewport
Maybe I'm doing something wrong but I can see my textures in any of blender's viewport modes. I see all materials grey. I know that the render in viewport is very fast now and I can see all the tweaks to the materials but for uv mapping and precise texture placing a preview on the viewport would be nice. It's also a very fast away to see which models have which materials.
Re: Texture view in Blender viewport
It'snt currently supported. so for texture you have to manually add it in UV editor to make it visible in blender texture mod.
1/ add cube
2/ unwrapp
3/ with all verticle selected or visible in UV editor choose the texture you want to see in you viewport.
4/ note that luxcore will not update by selecting automatically the map in your material node
5/ the update is done via UV editor
It' a bit annoying for archviz but we are just at the beginning
1/ add cube
2/ unwrapp
about this, I've found that a good workaround to speed up this workflow is the solution is adopting the Vray4Blender.
Their solution is: when you double click on the imagefile node, Blender load that image and show you on the object with that material assigned.
It speeds up a bit the texture visualization process.
Could it be doable here?
This is the relevant issue in the tracker: https://github.com/LuxCoreRender/BlendLuxCore/issues/38
I have spent some time in the past trying to set the texture in Blender's OpenGL viewport, but I did not succeed.
Would be great to find some example how to use the Blender API here.
Is their code open source? Do you have a link to it?marcatore wrote: ↑Mon Mar 26, 2018 2:46 pm about this, I've found that a good workaround to speed up this workflow is the solution is adopting the Vray4Blender.
How is this?
https://www.youtube.com/watch?v=4ojuuVt ... yucvtzBkN7
edit: since I was already in the area, I also added thumbnails (can be disabled).
That works for me.
I'm really impressed how fast you can solve my problems.
viewtopic.php?f=4&t=41&p=588#p586
Would have been faster if I had my notebook with me at uni today.
Great!!!
It seems exactly what we need...the next release I'll check it but it's perfect!
thank you
thank you
There is a little problem with the new option "show in viewport" : It doesn't respect material face matching. I mean sometime when i hit this button the texture cover the entiere object.
