Does the Ryzen 5 2400g have an integrated GPU ?jgrover110 wrote: Fri Apr 10, 2020 11:52 am Updated to 20.4.1, still not correct. CPU load reaches 100% in task manager. This must be hardware specific if other people cannot reproduce it.
HDRi and Light Tracing
Re: HDRi and Light Tracing
jgrover110
Yes it does, but I'm sure it's not using that. OpenCL device is labelled as "Ellesmere".Dade wrote: Fri Apr 10, 2020 12:11 pmDoes the Ryzen 5 2400g have an integrated GPU ?jgrover110 wrote: Fri Apr 10, 2020 11:52 am Updated to 20.4.1, still not correct. CPU load reaches 100% in task manager. This must be hardware specific if other people cannot reproduce it.
I also tried rendering with Luxcore standalone, same image.
One thing I found while exporting from Blender is that the exported camera FOV does not take into account the sensor fit method, which initially resulted in a much smaller FOV than anticipated
Don't they look quite different (original problem screenshot Vs. stand alone) ?jgrover110 wrote: Fri Apr 10, 2020 12:16 pm I also tried rendering with Luxcore standalone, same image.
The shadow in the first one is pitch black, I can get the same result if I set the number of CPU threads to 0. I will check again if I can reproduce this problem in some way.
jgrover110
This is just due to the ACES tonemapping.Dade wrote: Fri Apr 10, 2020 12:21 pm
This seems to be normal behaviour of LuxcoreUI specifically. Acutally had this question on ym mind for a while, maybe Dade can confirm if this is intended behaviour?jgrover110 wrote: Fri Apr 10, 2020 12:16 pm One thing I found while exporting from Blender is that the exported camera FOV does not take into account the sensor fit method, which initially resulted in a much smaller FOV than anticipated
If you render from a terminal using luxcoreconsole.exe the FOV will be as expected.
jgrover110
For sake of comparison, here is the render in Blendluxcore without ACES, only sRGB.
Yes, luxcoreui resets the screenwindow parameters to use the current window size (so you can resize the window).CodeHD wrote: Fri Apr 10, 2020 12:42 pmThis seems to be normal behaviour of LuxcoreUI specifically. Acutally had this question on ym mind for a while, maybe Dade can confirm if this is intended behaviour?jgrover110 wrote: Fri Apr 10, 2020 12:16 pm One thing I found while exporting from Blender is that the exported camera FOV does not take into account the sensor fit method, which initially resulted in a much smaller FOV than anticipated
jgrover110
This is a rendering with Caustic Cache disabled. This shows that the Light Tracing is working as there is a caustic from the metal cube, yet the shadows are still incorrect.
I have some serious trouble to notice any difference (aside from SDS paths)jgrover110 wrote: Fri Apr 10, 2020 1:45 pm This is a rendering with Caustic Cache disabled. This shows that the Light Tracing is working as there is a caustic from the metal cube, yet the shadows are still incorrect.
Here is a side-by-side comparison.
Still a tiny bit of color difference of the background plane but I think we can agree the shadow difference goes beyond that.
I could not replicate it (from within Belnder) with some settings variations (cpu/OCL, light tracing on/off, cache on/off)
I will try with standalone also, since it seems you were able to replicate it...
