Indeed.
Build succeeded.
Thank you.
Indeed.
  c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(39): error C4430: missing ty
       pe specifier - int assumed. Note: C++ does not support default-int (compiling source file C:\luxcorerender\LuxCo
       re\src\slg\rendersession.cpp) [C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-core.vcxproj]
         c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(41): error C3646: 'objectID'
       : unknown override specifier (compiling source file C:\luxcorerender\LuxCore\src\slg\rendersession.cpp) [C:\luxc
         c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(41): error C4430: missing ty
    0 Warning(s)
    714 Error(s)
Time Elapsed 00:00:38.26
--- FATAL ERROR RUNNING CMAKE ---I should have fixed this probelm.kintuX wrote: Wed Jan 22, 2020 2:17 pm Latest commits again break the windows cmake build:
(ending of console output)Code: Select all
... ... ... c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(39): error C4430: missing ty pe specifier - int assumed. Note: C++ does not support default-int (compiling source file C:\luxcorerender\LuxCo re\src\slg\rendersession.cpp) [C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-core.vcxproj] c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(41): error C3646: 'objectID' : unknown override specifier (compiling source file C:\luxcorerender\LuxCore\src\slg\rendersession.cpp) [C:\luxc orerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-core.vcxproj] c:\luxcorerender\windowscompile\build_cmake\luxcore\src\slg\sampleresult_types.cl(41): error C4430: missing ty pe specifier - int assumed. Note: C++ does not support default-int (compiling source file C:\luxcorerender\LuxCo re\src\slg\rendersession.cpp) [C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-core.vcxproj] 0 Warning(s) 714 Error(s) Time Elapsed 00:00:38.26 --- FATAL ERROR RUNNING CMAKE ---
Confirming. It now builds w/o problems.
