Magog wrote: Mon Dec 30, 2019 10:00 am I tried to install the latest build, but I always get this error..
You have a mismatch between Blender plugin version and LuxCore binaries version (i.e. with/without multiple UVs support). Are you sure to have updated both ?
Magog
Post by Magog »
I only downloaded the latest build and installed it.
u3dreal
Post by u3dreal »
Win Linux or OSX ??
portfolio http://q3de.com/
Magog
Post by Magog »
Win
Magog wrote: Mon Dec 30, 2019 9:37 pmWin
You should delete the installation, re-download the plugin and re-install. It should fix your problem.
Magog
Post by Magog »
Now work!
Tnx a lot!!!
u3dreal
Post by u3dreal »
There will be a problem if BlendLuxCore is already installed or better was activated during the same blender session.
If the lib is loaded blender will not load it again thus you get a missmatch of the python plugin and the pyluxcore.so library.
You need to restart Blender to make it use the newly installed library. This is the fact even if you deinstall the older addon. !
Enty
Post by Enty »
Hi there,
I wanted to test the latest version of luxcore to see the changes to the light-tracing, but neither the blender addon works, nor the stand-alone version.
I downloaded the standalone version, unpacked it and run the following command from within the directory but get this:
./luxcoreui scenes/cornell/cornell.cfg
./luxcoreui: error while loading shared libraries: libblosc.so.1: cannot open shared object file: No such file or directory
Similarly, when enabling the blender-addon I get this error:
  File "/opt/blender/2.81a/2.81/scripts/modules/addon_utils.py", line 351, in enable
    mod = __import__(module_name)
  File "/home/jero/.config/blender/2.81/scripts/addons/BlendLuxCore/__init__.py", line 23, in <module>
Exception:
Could not import pyluxcore.
ImportError: libblosc.so.1: cannot open shared object file: No such file or directory
It seems there is some missing library, but I can't find this required libblosc.so.1 in neither the standalone package nor the blender-addon.
u3dreal
Post by u3dreal »
Win Linux or OSX ??
Enty
Post by Enty »
I'm running Linux.
