Compile on MacOS 10.13
u3dreal
Re: Compile on MacOS 10.13
Post by u3dreal »
Both .... iwas able to get rid of the error with using jpgv8d now all seems fine
Just uploading a new version build with jpgv8d.
portfolio http://q3de.com/
u3dreal
Post by u3dreal »
Post by epilectrolytics »
I'm getting an installation error:
Modules Installed (BlendLuxCore) from '/Users/me/Desktop/BlendLuxCore2.3alpha0_jpgv8_osx.zip' into '/Users/me/Library/Application Support/Blender/2.81/scripts/addons'
  File "/Applications/Renderer/Blender.app/Contents/Resources/2.81/scripts/modules/addon_utils.py", line 351, in enable
    mod = __import__(module_name)
  File "/Users/me/Library/Application Support/Blender/2.81/scripts/addons/BlendLuxCore/__init__.py", line 23, in <module>
Exception:
Could not import pyluxcore.
ImportError: dlopen(/Users/me/Library/Application Support/Blender/2.81/scripts/addons/BlendLuxCore/bin/pyluxcore.so, 2): Library not loaded: @loader_path/lib/libtbb.dylib
  Referenced from: /Users/me/Library/Application Support/Blender/2.81/scripts/addons/BlendLuxCore/bin/lib/libembree3.3.dylib
  Reason: image not found
u3dreal
Post by u3dreal »
Oh ... guess i should have checked with the other mac. Looks like @loader_path does not work with subdirs .... fixed ... one sec i'll reupload.
LuxCoreui should work fine. Does it ?
OK fixed .. same link
yep, LuxCore.app works 8-)
u3dreal
Post by u3dreal »
Great job mate!
Benchmark scene (PathCPU) opens and renders in Blender!
Danish mood was crashing, will test further.
Thanks again for making this possible!
u3dreal
Post by u3dreal »
danish mood crahses here as well with ocl CPU enabled
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_ILLUMINATE Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_SAMPLE_BSDF Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_NEXT_VERTEX_RAY Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_SPLAT_SAMPLE Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_NEXT_SAMPLE Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_CAMERA_RAY Kernel
[LuxCore][621.028] [PathOCLBaseRenderThread::0] Kernels compilation time: 36ms
[LuxCore][621.040] Starting 8 native render threads
Assertion failed: (!bsdfSample.IsNaN() && !bsdfSample.IsInf() && !bsdfSample.IsNeg()), function RenderEyePath, file /Users/drquader/Documents/GitHub/LuxCore/src/slg/engines/pathtracer.cpp, line 554.
Abort trap: 6
Lol I was just zipping the crashlog but you beat me to it :lol:
Benchmark scene renders fine with GT750M OCL.
Also this beauty here works well.
u3dreal
Post by u3dreal »
Does it work with opencl GPU enabled ???
OK now it works on the pool scene ... strange.
