Simple Test Scene
Magog
Re: Simple Test Scene
Post by Magog »
Sharlybg wrote: Fri Nov 29, 2019 10:11 am So you don't have any caches on ?
Yes, I do.
You can see the screen in the first post..
PetrT
Post by PetrT »
PetrT wrote: Thu Nov 28, 2019 6:29 pm may be try to render with more resolution then needed and downscale to required
i mean to render in 4k or more dimensions if it possible
2000 samples is enough
Yes, I do.
Ok i see. You don't really need direct light sampling cache here. go uniform or log power. can we see your PGI all settings ( indirect light cache part) .
Magog
Post by Magog »
Changing the Denoise [BCD] finally has a good compromise
Magog
Post by Magog »
Reduce brute force radius scale to 2 or 4.
The lower the faster. too low and you get light leak. i usually start with 2 and increase only if needed.
Racleborg
Post by Racleborg »
That looks way better! :D
@Magog, can you post a test scene with just a single couch pillow (if the major problem with the denoiser is there) ? So I can check if there is some problem with Oidn and where it comes from (or is just a limit of the Intel software, at the end of the day all denoisers have some limit).
Magog
Post by Magog »
Dade wrote: Fri Nov 29, 2019 11:12 am @Magog, can you post a test scene with just a single couch pillow (if the major problem with the denoiser is there) ? So I can check if there is some problem with Oidn and where it comes from (or is just a limit of the Intel software, at the end of the day all denoisers have some limit).
https://drive.google.com/open?id=1ovyDS ... jvJ6KeWhVN
If I set the render to 4k and after the calculation of the kernel, blender crash!
I also noticed that with the Particle System of the carpet and vegetation in the external area, the calculation does not start.
Magog wrote: Fri Nov 29, 2019 12:21 pm
Thanks, checking.
Magog wrote: Fri Nov 29, 2019 12:21 pm If I set the render to 4k and after the calculation of the kernel, blender crash!
You may be running out of GPU memory, does it happens also if you try a CPU-only rendering (PATHCPU instead of PATHOCL) ?
Does it happen both with Oidn and BCD ?
Unfortunately, BCD denoiser requires a lot of RAM for each pixel so the total amount of ram used at high rendering resolutions is very high.
