I will test the build tomorrow but I can already tell you that everything below the water in your example looks very wrongly shaded.Dade wrote: Fri Sep 20, 2019 3:11 pmThis is sun+sky (with the same exposure so it is a bit over-exposed due the additional light source):
Note: the water volume of the scene has (a bluish) absorption (so it does intentionally take away some light).
...You have super overexposed surface and a single milimeter under water the surface drops 5+ stops of exposure...
