hi
I have worked over gold ,but diamonds don't look much brighter, how can i increase brightness only for diamonds in my scene .
cant add more lights it brightens whole scene.
control brightness of glass material for Diamond
Re: control brightness of glass material for Diamond
If you want brighter diamonds you should try to darken all other materials in the scene (gold and ground) and then increase overall brightness via tone mapper.
I like to use low or medium contrast HDR lighting for gemstones.
https://hdrihaven.com/hdris/category/?c ... &o=popular
That's what I did:
That one is not denoised (probably) different lighting:
- added volumes for world and diamond
- disabled camera volume
- switched engine to bidir and sampler to Metropolis
- set color profile to filmic
- mixed with denoised image 50/50
- maybe I forgot something
rnd 3-wasd-b.zip- (1.9 MiB) Downloaded 170 times
Here's a modified version with darker materials and larger aperture:
When I try to render this with caustics, I see a huge difference between BiDir and Hybrid
^ Bidir
v Hybrid (diamond=only glass node and gold = only metal node)
Last edited by epilectrolytics on Tue Jul 16, 2019 3:26 pm, edited 1 time in total.
If the diamond is gray, it means that the environment is gray (which is reflected).
Place some large area lights behind the camera so they can reflect in the diamond.
It's probably also important to have an accurately modelled "working" diamond shape (they are optimized to reflect as much light back as possible) and correct IOR (see our IOR node), otherwise total internal reflection might kill some of the highlights.
lighted with hdri
