volume light difference
I have some minor problems with volumetric light in different rendering engines, as for me the result that gives the path more predictable and correct, but here it looks strange in the bidir, and I didn’t need it to look that way, tell me, it looks normal , or did I make some kind of mistake ?, I just think that it shouldn't look like that.I also want to ask why the auto detect camera volume function is needed, it's just not in cycles, and it has never been useful to me in cycles.
Re: volume light difference
Thanks for your report.
Please upload the scene so we can check the problem more easily.
The auto detect function shoots one ray into the middle of the image. This ray hits an object, and the camera uses the exterior volume of the material it hit as its exterior camera volume. For this to work, all materials need to have the correct interior/exterior volumes set.
The camera rays have to start in the correct volume.DEBIHOOD wrote: Mon Jun 17, 2019 9:00 pm I also want to ask why the auto detect camera volume function is needed
okayB.Y.O.B. wrote: Mon Jun 17, 2019 9:09 pm Thanks for your report.
a little understood the essence of the function - for the correct display of the volume, thanks for the explanation, it just sounds too difficult for meB.Y.O.B. wrote: Mon Jun 17, 2019 9:09 pm The camera rays have to start in the correct volume.
- Attachments
- volume problem.blend
- (637.86 KiB) Downloaded 813 times
I think the problem is that the rays of the spot light have no volume set.
Volume settings for lights were not implemented yet unfortunately. This can be considered a missing feature in LuxCore.
In your scene, there are two ways to work around this:
- move the spot light outside of the "fog cube" - this way, the light is in an area without volume, which matches its missing exterior volume
- use your fog volume as world volume (in the world properties). This assigns the fog volume to everything where no volume is set, even to lights
Oh, first the volume settings for the camera, now for the light sources, now I understood that I didn’t understand anythingB.Y.O.B. wrote: Mon Jun 17, 2019 9:31 pm I think the problem is that the rays of the spot light have no volume set.
I understand that this feature will be necessary only for bidir, because in the path everything works fine and without any problems *maybe I'm wrong*
Of course it works, but some people will probably need to place the light inside the fog box using bidir, and they just can't do it because there are some limitations with thisB.Y.O.B. wrote: Mon Jun 17, 2019 9:31 pm In your scene, there are two ways to work around this:
What do you think, when this feature may appear? I don’t need it right now, but maybe it will be necessary in the future for me and other users like me
I discovered that in this scene, it also works to assign the fog as exterior volume on the suzanne and ground plane objects (had to create a material for them first, of course).
Apparently, bidir is not as tolerant as path regarding malformed volume setups.
Well, now I’ve just made sure that I’m completely confused with the luxcore volume setting, too little information about setting them up, please, if you can, give a link on how to use volume in luxcore, what is the difference between interior volume and exterior volume, in the wiki, I did not find any understandable information about them, just a couple of words, and yet why luxcore does not have a single way out for a volume, such as in cycles or eevee ????B.Y.O.B. wrote: Tue Jun 18, 2019 1:18 am I discovered that in this scene, it also works to assign the fog as exterior volume on the suzanne and ground plane objects (had to create a material for them first, of course).
Yes, the documentation is lacking on this topic.
A material describes the properties of a surface, while a volume describes the properties of the "empty space" between surfaces. The exterior of a mesh is where its normal points to, the interior is the opposite side.
"No volume" means that a clean volume with no absorption and IOR = 1 is assumed. When a ray hits a material, it will check from which side it hit the material (interior or exterior, depending on the normal). Then it will either bounce off or pass through the material and use the interior/exterior volumes it found on the material for its evaluation.
Usually, you only have to set the interior volume of a material if it is transparent in some way - otherwise, rays can never pass through its interior volume. Setting the exterior volume is only important if the object is inside another volume, like in your fog scene.
It looks like in Cycles you can only set the interior volume of a material. I do not know how they determine the exterior volume and if that is always going to be correct.
In LuxCore, you can do any crazy intersection of multiple volumes and still have it working correctly because you can specify the interior and exterior volumes of each surface. But maybe we could automate this a bit more, not sure.
I made an illustration about the problem in your scene, hope it helps.
The rays are fired from the light, since the light tracing is the problematic part in your scene.
You mean in the material output node?DEBIHOOD wrote: Tue Jun 18, 2019 7:42 am why luxcore does not have a single way out for a volume, such as in cycles or eevee ????
Yep
Thanks for explaining this, now I understand about what I need to adjust the volume to display correctly, but now there is a need to add pointer to exterior for all objects, and what if there are thousands of objects in the scene, they all need to change the material? or can i just add world volume?B.Y.O.B. wrote: Tue Jun 18, 2019 9:12 am Yes, the documentation is lacking on this topic.
Thank you so much for the illustrations, they helped me understand the work of volumes in luxcoreB.Y.O.B. wrote: Tue Jun 18, 2019 9:12 am I made an illustration about the problem in your scene, hope it helps.
Thank you for this explanation. For sure, we need a better documentation about volumes in luxrendercoreB.Y.O.B. wrote: Tue Jun 18, 2019 9:12 am Yes, the documentation is lacking on this topic.
Ps. The attached images and files are no more available.. Is there a way to reach them?
Thanks!
