Camera Volume test
wasd
Camera Volume test
Post by wasd »
Camera volume set to World Volume (or autodetect):
Camera volume set to ---:
Materials affected:
  • Glossy Translucent
  • Matte Translucent
  • Rough Glass
Materials not affected:
  • Glass
  • Architectural Glass
  • Null
volume_test-d.blend
(1.04 MiB) Downloaded 1056 times
wasd
Re: Camera Volume test
Post by wasd »
@B.Y.O.B. Could you look into this, please?
I doubt that it is a bug in the addon. Apart from the material type, the scene properties are the same.
It is either a bug in LuxCore or a problem in the scene setup.
Piita
Supporting Users
Post by Piita »
I can't reproduce it on my end. Using world_volume and autodetect both produce the same as cavo-1.jpg. I don't have the option to select the --- volume. Could this be an old bug that has recently been fixed? I use blendluxcore 2.2 beta 1 and luxcore 2.2 beta 2
Piitas.blog
Librem 5 - The privacy focused smart phone
Piita wrote: Sun Jun 16, 2019 5:08 am I don't have the option to select the --- volume.
"---" is not an actual volume, it just means no volume, you get it when you press the "x" on the far right.
Piita
Supporting Users
Post by Piita »
B.Y.O.B. wrote: Sun Jun 16, 2019 8:35 am
Ah, yes, that was it. Now I get the same red cube too
Piitas.blog
