I'm working on a new version of the "Visibility driven sampling of env. light sources (aka portals without portals)" (viewtopic.php?f=5&t=93).
The original version was using a single visibility map for all the scene. The new version instead uses many visibility maps, one for each cache entry with the entries evenly spread over all surfaces as usual (i.e. the same of PGIC and DLSC).
Indeed, being able to have a local visibility map, is far more accurate than using a global one. The draw back is an increase of memory required to store all maps.
Today, I have done the very first rendering with the new code. This is a direct light only rendering (100 samples/pixel) without visibility map:
and this with the new EVL cache:
It looks promising.
Env. Light Visibility Cache
Re: Env. Light Visibility Cache
Uhm ! juicy result for an early code ! congratulation Dade .
Looking good...
1. Shadows in the back wall still look quite noisy, why is that?
2. How bad is the memory footprint? Does it increase with scene complexity?
3. Can this be used for other light types too?
Maybe not enough sample. Was not intended to be 100%1. Shadows in the back wall still look quite noisy, why is that?
Clear as it is a direct comparison at same sample level.
Maybe, I'm also viewing it on a phone atm...Sharlybg wrote: Mon May 20, 2019 6:10 pmMaybe not enough sample. Was npt intended to be 100%1. Shadows in the back wall still look quite noisy, why is that?
Clear as it is a direct comparison at same sampne level.
Anyway, if there's a build I'll give it a proper try tomorrow, cause today I saw only an unsuccessful build on azure.
Indeed it looks promising!Dade wrote: Mon May 20, 2019 2:42 pm I'm working on a new version of the "Visibility driven sampling of env. light sources (aka portals without portals)"
Is "guided brute force path tracing" still considered for development later?Dade wrote: Sun Mar 03, 2019 9:29 pm The data collected by tracing photons are a gold mine: at the moment I'm in doubt between a new version of visibility map for infinite lights or guided brute force path tracing (when current stuff is done).
It was my main concern at the start however I haven't seen a noticeable increase of memory usage in this scene (it has about 1300 cache entries).lacilaci wrote: Mon May 20, 2019 5:01 pm 2. How bad is the memory footprint? Does it increase with scene complexity?
The complexity of the scene will increase the amount of cache entries required however it seems manageable at the moment.
It could in the future (see my next post).
This method is very similar to a guided method. It "guides" only for env. light sources but it could "guides" for any kind of incoming light (direct and indirect).epilectrolytics wrote: Mon May 20, 2019 7:07 pmIs "guided brute force path tracing" still considered for development later?Dade wrote: Sun Mar 03, 2019 9:29 pm The data collected by tracing photons are a gold mine: at the moment I'm in doubt between a new version of visibility map for infinite lights or guided brute force path tracing (when current stuff is done).
Looks promising indeed
Is this enabled by default?(replacing current visibility map) or is it a new feature/mode that has to be exposed in blender?
