I have a noob question, I like to render a scene using hdri map to light it, but composite background later applying different color correction. I can enable "Transparent Film" in camera settings but how can I retrieve background image(environment data)? In Cycle, you can do it Alpha Over Environment like screenshot below.
Composite environment
Re: Composite environment
You can leave "transparent film" disabled and just enable the Alpha AOV in the renderlayer settings. The Alpha AOV will give you a mask of the background.
Here are the nodes to replicate a setup like yours.
Great! Thanks for your quick response B.Y.O.B. as usual!
