BlendLuxCore Development
nigec
Re: BlendLuxCore Development
Post by nigec »
its seems really strange to deliberately alter the texture and make it 3 times bigger file size
nigec wrote: Thu May 09, 2019 4:57 pm its seems really strange to deliberately alter the texture and make it 3 times bigger file size
But one is PNG and the other is JPG :?: FILESAVER must use a lossless compression format.
nigec
Post by nigec »
Side by side lxs and cfg render the same so all good, when I did my original test it was a glossy material and the worn wood seemed a lot closer to the darker texture
It still seems odd to me but hey ho on we go lol
Hi !
Just wonder if it is possible to use GIF as animated texture ? that would be great ;)
You will have to split the gif into individual frames with an external program.
B.Y.O.B. wrote: Tue May 14, 2019 12:53 pm You will have to split the gif into individual frames with an external program.
this is the process i want to skip. just like unreal engine you use mp4 video as texture.
Cycles also can use video as textures : https://www.youtube.com/watch?v=ZBv3PB7HW9o
i'am making some animation and that will speed up things.
Support for videos/animated gifs could be added to LuxCore. However it might introduce a further dependency because we would need to extract frames from the videos, something like FFMPEG could be used.
B.Y.O.B. wrote: Tue May 14, 2019 5:28 pm Support for videos/animated gifs could be added to LuxCore. However it might introduce a further dependency because we would need to extract frames from the videos, something like FFMPEG could be used.
IS this can slow any part of the rendering process ? something like long compilation time.
Sharlybg wrote: Tue May 14, 2019 5:43 pm IS this can slow any part of the rendering process ? something like long compilation time.
No, I don't think so.
