PhotonGI cache
Re: PhotonGI cache
The only good bug, it is a dead one:
One man to rules them all ! :!:
a pretty hard battle. I hope this one will not come back again.too annoying to see this dirt on a so bright new feature.
marcatore
Re: PhotonGI cache
Post by marcatore »
Good bug hunting!!! :)
@lacilaci black room is my guilty :)
andreymd87
Re: PhotonGI cache
Post by andreymd87 »
so decided to make a real comparison between corona and luxcore GI. some little details are different but main materials are almost equal. i used only environment flat color in both engines. however to make the window light pixel color identical i needed to set the gain of luxcore environment to 4. this might be visible in the scopes of the both exr images. however the interior of luxcore is still darker. i tried to tweak the settings as much as possible but could not get a brighter indirect light as corona. note that i used portal material in glass in corona. in luxcore is just a null(transparent) material. maybe this is the cause why the indirect lighting is still darker than needed. maybe there is possible to add a special gain for indirect light? :?: :?
Re: PhotonGI cache
Post by lacilaci »
andreymd87 wrote: Sat Mar 02, 2019 4:57 pm so decided to make a real comparison between corona and luxcore GI. some little details are different but main materials are almost equal. i used only environment flat color in both engines. however to make the window light pixel color identical i needed to set the gain of luxcore environment to 4. this might be visible in the scopes of the both exr images. however the interior of luxcore is still darker. i tried to tweak the settings as much as possible but could not get a brighter indirect light as corona. note that i used portal material in glass in corona. in luxcore is just a null(transparent) material. maybe this is the cause why the indirect lighting is still darker than needed. maybe there is possible to add a special gain for indirect light? :?: :?
What are your luxcore and luxcore cache settings(how does cache debug look like)
What is the difference between using cache and not using cache in your luxcore render?
andreymd87
Re: PhotonGI cache
lacilaci wrote: Sat Mar 02, 2019 5:02 pm
better try yourself. load it with UI. there you will also see the corona exr in editor.
https://drive.google.com/file/d/1oEqi3_ ... sp=sharing
upd. without cache is even darker.
Re: PhotonGI cache
Post by lacilaci »
I can't look at it right now, but tomorrow or after weekend. I suspect default power of luxcore flatcolor is too weak (it definitely is compared to sky for example)
andreymd87
Re: PhotonGI cache
lacilaci wrote: Sat Mar 02, 2019 5:43 pm I can't look at it right now, but tomorrow or after weekend. I suspect default power of luxcore flatcolor is too weak (it definitely is compared to sky for example)
yeah, that's why i increased it to get identical power.
zuljin3d
Re: PhotonGI cache
Post by zuljin3d »
yep!! last build works perfectly.
no dark area. and black walls
hdri opencl
hdri opencl
hdri pgi
hdri pgi
Re: PhotonGI cache
Sincerely, pretending to have the same outputs from 2 totally different rendering engines because you are inserting the "same" inputs is a veeeeery long shot.
I mean, are the models for light sources, materials, textures, camera, film response, etc. the same ? Are all the input values expressed with the same physical units ?
I wouldn't loose my sleep over that.
Re: PhotonGI cache
The corona render i had try in the past always seem to have a tonemapper setup for maximum interior light. Sometime this cause exterior to be too bright by default. At least for the version i had.
