Page 2 of 2
Re: New Free Shader Package
Posted: Sat May 01, 2021 6:29 pm
TAO wrote: ↑Sat May 01, 2021 5:42 pm
I create a small test to convert lux objects from blender to 3dsmax it is working but needs more work, before i go to the next step i need a few scenes or objects to work with.
That is awesome news indeed. And you can start right out of the box with blendluxcore embeded library free assets.
Just open blender with blendluxcore copy already installed and after that drag and drop free assets you want to test.
Make sure to select Append instead of link in the N panel Luxcore online library parameter.
Great Job
Posted: Mon May 03, 2021 1:13 am
by TAO
Great, just one question.
Am i doing something wrong, because it will be stuck on 0% all the time?
If i try many times finally it will download a few objects but even with the download manager, it takes time to start the download.
Posted: Mon May 03, 2021 9:07 am
by TAO
i manage to test a few scenes and i think the automatic conversation of the scenes from Blender to 3dsmax won't work as it expected, because there are many shader/map nodes in blender that not exist in 3dsmax.
For example Pointiness, Band, etc.
So either i need to create a map for this situation or think of another solution.
Posted: Mon Jun 14, 2021 2:01 pm
by TAO
I tried the Dade solution and it was perfectly working with the current objects, load Ply, and textures in LuxCore format but I face another issue, and that is the objects and materials are not editable and they are all statics. for using the pack exactly as it is there is no issue but most artists want to be free to edit objects and more likely materials that make it a bit complicated.
Any idea or solution here ?
Posted: Mon Jun 14, 2021 6:59 pm
TAO wrote: ↑Mon Jun 14, 2021 2:01 pm
You need to translate the properties in your 3DsMax nodes tree (i.e. 3DsMax material and texture definitions).
Posted: Mon Jun 14, 2021 7:04 pm
by TAO
Dade wrote: ↑Mon Jun 14, 2021 6:59 pm
yes, that's what I'm intending too but there are too many parameters and it needs lots of times, another thing is not all nodes exist in 3dsmax so I face big issues with this kind of node. most of the dynamic nodes do not exist in 3dsmax.
