S0rda wrote: Fri Feb 15, 2019 12:23 pm
Are there any settings for OIDN? To be able to adjust the radii and stuff, as in the usual bvd denoiser?
Not really.
The options available to developers are listed in this table: https://github.com/OpenImageDenoise/oidn#rt
But as end-user, you always want these settings:
- normal and albedo AOVs as additional input
- HDR mode on
- sRGB mode off
So these settings are not exposed in the UI, because changing them would only make the result worse.
Yes, noise in the albedo AOV essentially disables the denoiser in those areas.
Let's see if noise-free reflection/refraction in 1 sample can be implemented in LuxCore (I asked here). If not, it might be a good idea to drop the reflection entirely (in the albedo AOV) or prefer reflection/refraction based on IOR.
By the way guys, could you stop doing full quotes so often? It makes the thread harder to read.
B.Y.O.B. wrote: Sat Feb 16, 2019 1:50 pm
