OpenImageDenoise
Re: OpenImageDenoise
Post by B.Y.O.B. » Fri Feb 15, 2019 12:29 pm
S0rda wrote:
Fri Feb 15, 2019 12:23 pm
Are there any settings for OIDN? To be able to adjust the radii and stuff, as in the usual bvd denoiser?
Not really.
The options available to developers are listed in this table: https://github.com/OpenImageDenoise/oidn#rt
But as end-user, you always want these settings:
- normal and albedo AOVs as additional input
- HDR mode on
- sRGB mode off
So these settings are not exposed in the UI, because changing them would only make the result worse.
sanjinms
Post by sanjinms » Sat Feb 16, 2019 11:29 am
Some parts of transparent materials (arch glass in this case) are still noisy after OIDN pass?
Image + OIDN
Albedo pass
Post by lacilaci » Sat Feb 16, 2019 11:52 am
Do you by any chance use metropolis sampler? I've noticed that metropolis takes quite some time for clean albedo and normal aov's.
sanjinms
Post by sanjinms » Sat Feb 16, 2019 1:11 pm
I will try Metropolis!
Post by lacilaci » Sat Feb 16, 2019 1:13 pm
No, I was suggesting exact opposite. Don't use metropolis.
sanjinms
Post by sanjinms » Sat Feb 16, 2019 1:19 pm
Ohh sorry.... I Didn't use metropolis....
sanjinms
Post by sanjinms » Sat Feb 16, 2019 1:22 pm
I got same effect on exterior scene.
sanjinms
Post by sanjinms » Sat Feb 16, 2019 1:33 pm
However, blendluxcore and oidn are awesome :roll:
Post by B.Y.O.B. » Sat Feb 16, 2019 1:50 pm
Yes, noise in the albedo AOV essentially disables the denoiser in those areas.
Let's see if noise-free reflection/refraction in 1 sample can be implemented in LuxCore (I asked here). If not, it might be a good idea to drop the reflection entirely (in the albedo AOV) or prefer reflection/refraction based on IOR.
By the way guys, could you stop doing full quotes so often? It makes the thread harder to read.
sanjinms
Post by sanjinms » Sat Feb 16, 2019 3:36 pm
Sorry for full quotes, it's my fault.
